Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD200X
Optoma Pico
Epson EMP-TW700
Acer X110
Panasonic PT-AE3000
Optoma ES522
 More...Prices updated November 21st at 8:30pm and include delivery.
Old 25-11-2005, 10:31 AM   #1 (permalink)
Thanks: Gave 9, Got 9
Hitachi TX100: "Please replace the lamp and then reset the timer"?
My TX100 has clocked up 1700hr on the lamp timer and when I powered it on yesterday, the above message appeared which I was kind of expecting.
However, the brightness of the TX100 seems to be pretty much the same as when I brought it from day one and when I change the Iris from 1 to 10, each increment gives a dramatic increase in the light output of the TX100 which suggest that there is still life in these bulbs yet.
I did reset the lamp timer in order to get rid of the above message but did not replace the lamp and asside from the 'fluttering' I get with this TX100 (constant change in the TX100's light output every 5 secs) it is running as normal - btw how do I know what lamp to replace?
What does everyone advise and is there any TX100 owners who have clocked over 2000hr?
tk2001 is offline   Reply With Quote
Old 25-11-2005, 10:39 AM   #2 (permalink)
PJTX100's Avatar
Thanks: Gave 256, Got 280
At a guess this is an internal software driven threshold which acts as a simple reminder. It wouldn't surprise me if it appeared every 100hrs from now on to "nag" you - but that's just a guess.
You don't have to replace the lamp until there's a dramatic degredation in light output, from what i've read lamps can be fine until they are very near their last legs.
You'll need to go to a specialist lamp supplier to get one, they are a few hundred quid I think. It will be a specific lamp for the TX100.
Must say the constant fluttering in light output you describe sounds very annoying and I'm surprised you are putting up with it...PJ
A man's life in these parts often depends on a mere scrap of information.
PJTX100 is offline   Reply With Quote
Old 25-11-2005, 11:02 AM   #3 (permalink)
cyberheater's Avatar
Thanks: Gave 33, Got 125
I've recently looked for a replacement lamp for my TX100 as a backup and they can be had for less then 150 quid which is a result.
You can stuff LCD. It's high def DLP all the way for me
cyberheater is offline   Reply With Quote
Old 25-11-2005, 3:23 PM   #4 (permalink)
PJTX100,
As my PJ is no longer under warranty, theres nothing I can do but put up with the constant 'fluttering' and it seems this is a common problem with TX100s? In a sense I put up with it because I see myself being lucky enough that it has managed to clock up as many hour as it has.
Old 25-11-2005, 3:26 PM   #5 (permalink)
cyberheater,
Is £150 the cheapest you can get a TX100 replacement bulb for and does that include delivery?
Does anyone else knows a cheaper price and are TX100 owners going to replacement the bulbs on their PJ or upgrade to the TX200?
Old 25-11-2005, 3:45 PM   #6 (permalink)
http://www.misco.co.uk/productinform...affiliate=2024
for less then 150 quid. Not sure if it also includes delivery.
The bulb is the DT00661
Do a google for it.
Old 25-11-2005, 10:27 PM   #7 (permalink)
Thanks: Gave 2, Got 4
I've got a TX100 which occasionally has a flickering problem. It randomly comes and goes. I suspect its temperature related. Its better than it was in summer and i've taken the fan off whisper mode.
twarde is offline   Reply With Quote
hitachi, tx100
