Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD200X
Optoma Pico
Epson EMP-TW700
Acer X110
Panasonic PT-AE3000
Optoma ES522
 More...Prices updated November 22nd at 5:30am and include delivery.
Component Vs RGB (Scart?) Vs Svideo Vs Composite Nic Rhodes Interconnects, Speaker Cables and Switches 153 29-10-2009 10:12 PM
"pink" picture wgen using rgb via component nisnos Rear Projection Televisions 7 18-11-2005 3:19 PM
Better Component cable = Better picture? weyland-yutani Interconnects, Speaker Cables and Switches 16 29-09-2005 10:49 AM
Picture Quality scart V Component Optiplex All-in-one Systems 1 13-12-2004 12:27 AM
component cables+no picture! godzilla DVD Players 1 05-02-2003 2:46 PM
Old 25-11-2005, 1:44 AM   #1 (permalink)
Thanks: Gave 2, Got 0
No Picture Through Component
I've just put all of my home cinema setup back together after decorating the living room. Before I dismantled it I had my Panasonic ES310 DVD-R connected by SCART to my CRT TV and by component to my Infocus X-1 projector.
Now that's it's back together, the setup is identical except that the CRT has been replaced with a Sharp LC32P50E LCD TV. But now, although I get a picture through the DVD recorder on the TV the projector will not pick up the signal through the component connection. It will display the signal from my other DVD player which is connected using S-Video.
The problem persists even if I disconnect the SCART from the DVD Recorder and the S-Video from the projector. I've definitely got progressive scan turned on on the DVD player, I've done a factory reset of both units and unplugged them for several minutes before trying again - still no joy! Why can't I get a picture on the projector through the component input?!
phil2415 is offline   Reply With Quote
Old 25-11-2005, 8:10 AM   #2 (permalink)
cyberheater's Avatar
Thanks: Gave 33, Got 125
start of with the basics.
Disconnect everything and then set up just the DVD recorder to the projector via component. If that works you go on to the next bit and connect your tv etc...
Build up your system in bits and test as you go.
You can stuff LCD. It's high def DLP all the way for me
cyberheater is offline   Reply With Quote
component, picture
