Sony VPL-HS1 Or Sanyo PLV-30 or maybe even a Sony 10ht or 11ht HELP
Old 13-11-2001, 7:42 PM   #1
neo-uk
Posts: n/a
Hi all
Well need some help here been looking for a projector for 2 years now and can not seem to find the right one for me.
I have Demd or seen
1. a sanyo-PLV-30
Why did i not go for this one well it has the most screen door
effect i have seen on any projector its the worst for it
the blacks a fantatic becaseu of its 400-1 contrast and
500 ansi buld which is more than anyone needs dont know
why companys keep butting more ansi in it just makes worse
blacks anyway that what put me of that one
2. a sony VPL-HS1
It has fantastic picture quality no screen door at that i can see
the colours a great and very sharp but sony have put to much ans into it casueing the black to be washed out
3. a sony ht10
real good picture but have had a chance of an ex dem model
for £3000 with 1000 hours used on the bulb dont know
4 sony ht11
have not seen it but its £5300 dont knw if i want to spend that sort of money
i wiuld love a projector of the sanyo plv 30 blacks and the picture quality of the sony VPL Hs1 and it would be a big hit i think
i would have prob bought the sony VPL-HS1 but guess what sony left out one inportant thing that all projectors have a cellein mount version but no thay had to make it desktop only
i dont know what to do i am sick of wating for some sort of decent projector i might go fot the sony 10ht used for £3000 with 1000hrs left on it what do you all think
i hate DLPs becasue i can spot the rainbow effect on all
will the iscan get rid of the screendoor on the sanyo-plv30
i dont know how that got a good picture review its in your face on that one i have herd the iscan do not work well with plv30 ???
is there any new projectors due out from sanyo or anyone just looked at the tos mt3 waste of time the ansi is 850 with 400 contras the blacks would be washed out ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
sick help well hopw someone can shed dome light about this or anything
thansk to all
neo
Old 13-11-2001, 11:05 PM   #2
General Skanky's Avatar
17,672, Level: 32
Points: 17,672, Level: 32 Points: 17,672, Level: 32 Points: 17,672, Level: 32
Thanks: Gave 24, Got 31
Thumbs up
Musical Images are advertizing new Sony 10's at £3400!!!
12 month warranty and a new lamp. Good deal. Flick through the latest issue of HCC and see their ad.
Old 14-11-2001, 8:23 AM   #3
7,412, Level: 20
Points: 7,412, Level: 20 Points: 7,412, Level: 20 Points: 7,412, Level: 20
Thanks: Gave 5, Got 20
I think with the PLV30 if when setting the focus - if the focus is super sharp then the screen door is visible - so what you have to do is de-focus slightly and then the picture is more smooth - thats what I do anyway
The ISCAN had a problem with the PLV30 but I have read that a new main board for the ISCAN has been fitted eliminating the problem - the problem been losing the film sometimes with scenes with high bright content - try opening of Toy Story 2 if wanting to test it - but it should work now
The PLV30 is definitely a better picture with progressive PAL input and has a good benefit of accepting the 576 PAL progressive mode - I don't know if the other projectors allow this? Normally they say the accept progressive signal but it is only 480 which is NTSC only ( Region 1 ) - so they don't sync to Region 2 progressive from a DVD player
For PAL progressive there are a number of options - The ISCAN PRO, Skyworth DVD player and the Denon DVD 2800. The Denon should be a good bet and had great reviews for sound as well as picture - but actual people that have used it have complained about audio drop out and some progressive picture anomalies - so before buying it a home trial to watch a number of DVD's would be the best thing
Old 14-11-2001, 11:03 AM   #4
7,884, Level: 21
Points: 7,884, Level: 21 Points: 7,884, Level: 21 Points: 7,884, Level: 21
Thanks: Gave 15, Got 36
I guess it depends on your preference, your pretty much looking at models I had at home for a week to demo.
The PLV30 was loads cheaper the the 10HT at that time, obviously there's some quite good deals on the Sony at the moment though.
Obviously I'm going to say the 10HT because that's what I bought in the end, but here's why.
Loved the blacks on the Sanyo, however it's drawbacks were (for me anyway), no widescreen mode, the difference in picture between the 2 was far less when both were running in 4:3, however as soon as switching to widescreen the Sony simply looked amazing, maybe you should add the PLV60 to your list although I haven't seen one.
The black level seemed to be at the expense of detail, now you can say I didn't have it set up correctly (although I had it for a week and messed around with all the settings on both projectors), but the dark scene in mission impossible II where Tom Cruise was at the party where he meets the women, I watched on the Sanyo and it looked great, then I switched to the Sony and suddenly noticed his jacket was a velvet jacket and not a plain dinner jacket. Whatever I did I couldn't get the Sanyo to produce this detail, and that to me outweighed the black level (again personal choice).
Finally the fan noise on the Sanyo was a lot higher (this may not be a problem for you.
I would have been very happy with Sanyo had I not directly compared it too the Sony, so if you only want too spend 2K on a projector don't compare it with anything over twice the price.
Anyway hope this helps
Slingshot
P.S. I also looked at a couple of others, and one I thought was OK was a Davis Cinema One, which you can get pretty good deals on at the moment since Davis have stopped making projectors.
P.P.S A guy from this board, Nick Dale (are you still around Nick ?)also came round and viewed these projectors at my house and sort of wrote his own review between them if you can search the forum and find it, probably around 6-8 months ago.
Old 14-11-2001, 8:27 PM   #5
17,672, Level: 32
Found this for you Neo on following another persons links.
Hope it's of use.
http://www.munsil.com/VW10HTFaq.htm
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
3 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
7 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 11th at 7:30pm. Prices include delivery.
