Hi Joe,
good to hear from you, thanks for confirming the cable is correct, the length I have is 10m.
I know this is over the recommended 7m for DVI, however I wanted to make sure it was the correct cable before opening the packet and had to send it back.
I will test it soon and if no good then will have to rethink the positioning of DVD player in relation to the projector.
