Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD200X
Optoma Pico
Epson EMP-TW700
Acer X110
Panasonic PT-AE3000
Optoma ES522
 More...Prices updated November 21st at 6:30pm and include delivery.
Old 16-09-2005, 7:46 AM   #1 (permalink)
Sky Picture is Pants!
I have a Thomson Sky box (freebie when i signed up with Sky) and cannot get a decent picture out my projector from it. I have a scart to VGA adaptor but the sky picture coming from the projector just jumps about all over the place and then loses the signal. (I have a Themescene H30A) I'm assuming it's a week signal output from the sky box but am not 100% Sure. I tried a 2m VGA cable (instead of my 10m) cable and the signal was less jumpy but still jumping . Is it more than likely that it is beacause it is a cheap Sky box? It's a pity cause the only picture i get just now is composite and it's rubbish. Are there any cheapo Sky boxes out there that have component or S-Video output?
Dirk_Diggler is offline   Reply With Quote
Old 16-09-2005, 8:25 AM   #2 (permalink)
Anyone????? Is there such a thing as a scart to 3 lead RGB cable? I could connect the three RGB leads to my Component cable if this was the case.
Old 16-09-2005, 8:34 AM   #3 (permalink)
gingercat's Avatar
Thanks: Gave 3, Got 14
You might want to wait longer that 45mins before you start complaining that nobody has replied
Lots of people will have read your thread but not have an answer (like me). I believe that the Sky picture is quite bad to start with - my brother always comments that my Freeview picture is much better than his Sky one.
Not sure if you're having a box problem or what I'm afraid. Do you know anyone that could give you a quick lend of their box to test your cable/projector combination with another box?
Hitachi PJ-TX200, Panasonic TX32LXD85, Yamaha RX630, Paradigm PDR-10, Paradigm CC-130, Wharfedale Diamond 5.1, XBox, XBox360, Wii, PCH-A110.
gingercat is offline   Reply With Quote
Old 16-09-2005, 8:37 AM   #4 (permalink)
gizlaroc's Avatar
Thanks: Gave 58, Got 304
Does your projector accept RGBs?
If yes you need a scart to 4 phono cable wired for Red, Green, Blue and Sync, or Scart to VGA wired the same.
If no you need to get a JS Scart-Component converter.
You are not seding it the correct sync signal by the sounds of things, what adapter are you using exactly?
No Darling.......I've had it for months
gizlaroc is offline   Reply With Quote
Old 16-09-2005, 10:53 AM   #5 (permalink)
braiden's Avatar
Thanks: Gave 181, Got 51
I have the Sky Thompson box, and IMHO the picture really isn't that bad none of the problems you mentioned and in fact the picture from channel 5 is really quite good especially with programs like CSI and House ect...
In case you're wondering It's connected to an infocus 4805 via a composite video cable, I dare say that if I were able to conect it through component it would be even better.
You may have a fualty box, had to have mine swapped out three times after they installed the first one. Give sky a call and see if they can send out an engineer.
braiden is offline   Reply With Quote
Old 16-09-2005, 10:57 AM   #6 (permalink)
gizlaroc's Avatar
He is not getting the picture to sync.
When you say the picture is crap, is what you really mean is you can't get a picture?
Old 16-09-2005, 12:25 PM   #7 (permalink)
I get a picture which is broken up ie some horizontal sections of the picture are offset to the left and jerky and visa versa.
Old 16-09-2005, 12:34 PM   #8 (permalink)
It accepts Scart RGB (DVI-I via supplied scart to VGA & VGA to DVI-I adaptor). My DVD Player works fine through the same set-up. The scart output signal is spot on through set-up whereas the Sky box isn't.
Old 16-09-2005, 5:54 PM   #9 (permalink)
Thanks: Gave 8, Got 11
My Sky box looks pretty good on my Screenplay 5700, connected by s-video.
From my limited knowledge I agree that you may be confusing RGB with component. But I'm not entirely sure myself.
Screenplay 5700, 7' Electric screen, Denon AVR-4306 & DVD-3910, Sky+, Squeezebox 3 + Boom + Controller + iPeng on iPhone, 26" LCD, REL Stampede, Futronix, RC9200 Remote, X-box 360
My Home Cinema Website
BruceH is offline   Reply With Quote
Old 17-09-2005, 7:48 PM   #10 (permalink)
Thanks: Gave 1, Got 2
I've got the earlier H30, all of the sources are connected into a switch box with the output connected to the projector using the SCART to VGA adaptor supplied with the projector.
I use a 10m VGA cable with gold connectors which if I remember cost around £40 from "Lindy".
The Sky box is a fairly old Panasonic but the picture is pretty good and I've never had any probs with it.
MikeD is offline   Reply With Quote
Old 19-09-2005, 3:02 PM   #11 (permalink)
Thanks: Gave 1, Got 0
You may want to experiment with your sky box settings via the picture settings menu. i messed with mine as I could not get it to run on my new infocus 5700, and after a bit fo trial and error it fired up fine. I changed scart setting to RGB (from PAL) and I think turned the scart either from off to on or vice versa I cannot recall).
Have a mess about and see if it improves.
simch is offline   Reply With Quote
pants, picture, sky
