From the info I can gather this is a video only device. It wont scan high enough to make use of progressive scan outputs on DVD players or from linedoublers/scalers.
The 4:3 burn is to be expected and may not be a problem. You'll just have to re-size the image area to use the surface of the phosphor that is inside the 4:3 burn in. Not really a big deal.
There is no point in re-tubing it unless you have a source of s/h tubes. New ones, if available, would cost more than the thing would be worth.
If you can see a picture replayed on it and it seems to function then £150-£200 could be a fair price.
Gordon
StereoStereo
Intelligent Solutions for Intelligent Homes !
