Has anyone sent Sony HS50 away for firmware upgrade yet?
Old 21-04-2005, 9:38 PM   #1
5,398, Level: 17
Points: 5,398, Level: 17 Points: 5,398, Level: 17 Points: 5,398, Level: 17
Thanks: Gave 6, Got 2
Hi, I have arranged for my HS50 to go to Sony at Pencoed but just want to check that it's worth it. Do they fix the 720p overscan, and do they do anything else? Has anyone had this fix yet? Please help!
Old 22-04-2005, 1:27 AM   #2
4,955, Level: 16
Points: 4,955, Level: 16 Points: 4,955, Level: 16 Points: 4,955, Level: 16
I have had discussions with Sony here in Perth and they don't appear to have a clue.
I'm not that concerned at the moment as using 1080i via DVI to VGA converter into VGA input in the Sony and am getting excellent picture -subject to source material.
Oz now transmits a high proportion of telecasts in HD format - Quite breath taking.
Old 22-04-2005, 7:03 AM   #3
paul1672's Avatar
5,258, Level: 17
Points: 5,258, Level: 17 Points: 5,258, Level: 17 Points: 5,258, Level: 17
Thanks: Gave 34, Got 23
hi there.
not sure if pencoed is in the uk but i have returned my hs50 to sony uk primarily as it was faulty but i also requested that the firmware be done at the same time.
i returned it over a month ago and i've recently been informed the pj is fixed but awaiting the firmware upgrade.....
i was advised it should be back at the store i purchased it from approx 5 days later but that was a week ago now and still no sign.....
hope that helps
paul
Old 22-04-2005, 10:55 AM   #4
5,460, Level: 17
Points: 5,460, Level: 17 Points: 5,460, Level: 17 Points: 5,460, Level: 17
I've been waiting for Lal at Gultronics to find out from Sony UK whether the firmware upgrade is possible now...still waiting.....
Old 22-04-2005, 4:02 PM   #5
paul1672's Avatar
5,258, Level: 17
i've just been informed it was only as few days ago that sony service centre got set up for the upgrades but my pj still hasn't been done.
i'm hopefully gonna get an update to my situaton by tuesday......
paul
Old 22-04-2005, 7:16 PM   #6
Zig
Posts: n/a
I am in the same situation as Paul, I have been without my projector for 5 weeks and am not too impressed by the Sony service.
Old 25-04-2005, 10:58 AM   #7
5,398, Level: 17
Thanks for the replies - I've sent it and will let you know how I get on.
Old 25-04-2005, 8:19 PM   #8
5,460, Level: 17
I dropped mine off with Gultronics today so they can send it back to Sony UK to apply the firmware patch and to fix the panel misalignment that is causing the final vertical row of pixels to be green - all this after two AE500 bulb flickers problems last year
Old 27-04-2005, 11:34 AM   #9
Zig
Posts: n/a
I have just rung Discount Electrical to see what the situation is. Apparantly there is some delay with the firmware with no date available as to when it is expected to be resolved
I am not impressed with Discount for failing to inform me of anything over the last six weeks unless I pushed them or Sonys poor service.
Old 27-04-2005, 12:24 PM   #10
5,460, Level: 17
Originally Posted by paul1672
hi there.
hope that helps
paul
Sorry Paul, do you mean your projector was meant to be back at the shop five days after the call you made, or five days after the firmware is upgraded (which sounds like it could still be some time).
Old 27-04-2005, 12:44 PM   #11
Zig
Posts: n/a
It was meant to be back at the shop in 5 days, Paul's was sent back for repair just after mine to the same place. We were both told that the projectors were both repaired but sat on the shelf awaiting firmware which could take a few days to get sorted. Mine was posted back six weeks ago today, not an acceptable situation imho.
Old 27-04-2005, 2:23 PM   #12
paul1672's Avatar
5,258, Level: 17
yep,zig is correct.
i was advised it would be back with discounttv approx 5 days after the call i made.....
i was also advised it was only a few days earlier than the call i made that sony service centre had been set-up for the upgrades,now it seems they aren't even ready.......
i heard from discounttv yesterday saying that the firmware update is still not done and no date is know either.
this totally contradicts what i was told earlier and i am now getting very frustrated.......
sony really do need to sort themselves out.
cant really blame discounttv (apart from lack of frequent updates without being asked) as they can only tell us what sony tell them.
hopefully it wont be too much longer though.
i just hope they advise me of the day to expect it to be delivered back to me so i can arrange for someone to be home rather than just send it and i miss it......
all the best
paul
Old 04-05-2005, 7:30 PM   #13
Zig
Posts: n/a
Anyone any idea if Sony have pulled their finger out yet?
Nearly Watchdog time I think.......................
Old 04-05-2005, 7:32 PM   #14
paul1672's Avatar
5,258, Level: 17
i've sent yet anothr email off to discounttv tonight.
hopefully i'll have a positive reply tomorrow......
paul
Old 04-05-2005, 7:38 PM   #15
Zig
Posts: n/a
I think we can rest assured DIY and gardening will not be interupted by film viewing for at least another weekend
It makes you wonder if its some sort of conspiracy.
Old 05-05-2005, 2:11 PM   #16
SSB SSB is offline
5,210, Level: 17
Points: 5,210, Level: 17 Points: 5,210, Level: 17 Points: 5,210, Level: 17
Thanks: Gave 52, Got 82
How does one check the firmware number on the HS50?
Old 06-05-2005, 8:01 AM   #17
Scotty's Avatar
8,618, Level: 22
Points: 8,618, Level: 22 Points: 8,618, Level: 22 Points: 8,618, Level: 22
Thanks: Gave 7, Got 423
"on the remote push enter, enter, up, down, enter, up then the menu should be at the botten new menu"
Old 06-05-2005, 8:50 AM   #18
6,658, Level: 19
Points: 6,658, Level: 19 Points: 6,658, Level: 19 Points: 6,658, Level: 19
Thanks: Gave 0, Got 6
Post
Sounds like a cheat for a computer game does it give you infinite lives?
Old 06-05-2005, 10:17 AM   #19
SSB SSB is offline
5,210, Level: 17
Thanks Scotty and Zoolap - have just received mine and wanted to check it had the new f/w. It seems like it does (1.02) - which is good news.
Old 09-05-2005, 4:29 PM   #20
Zig
Posts: n/a
Well at last some good news, my projector has been updated and was undergoing testing today. I hold little hope of getting it back this week having witnessed Sonys lack of speed but it is nice to finally know things are moving.
Old 09-05-2005, 5:45 PM   #21
paul1672's Avatar
5,258, Level: 17
i also heard from discounttv today and was advised sony have finally started doing the upgrades,if thats the case mine shouldn't be too far behind you mate as i returned mine the very next day after you.....
let us know when you finally receive yours back.
paul
Old 09-05-2005, 5:53 PM   #22
Zig
Posts: n/a
I was told they would ring me as soon as they got it back to arrange delivery. I will let you know as soon as I hear from them.
I have a few days now to dust of the HTPC, wipe the cobwebs from the screen and maybe buy a new film or two.
Old 10-05-2005, 8:56 AM   #23
5,398, Level: 17
Well, according to Sony, mine's coming back tomorrow so I'll let you know if it does, and if it's fixed.
Old 10-05-2005, 9:37 AM   #24
Zig
Posts: n/a
When did you send yours back Blindman and was it faulty or just the firmware upgrade it was returned for?
Old 10-05-2005, 1:19 PM   #25
5,398, Level: 17
It was just the firmware upgrade, and I sent it back on 22/04. Cheers.
Old 10-05-2005, 2:29 PM   #26
paul1672's Avatar
5,258, Level: 17
interesting....
so,if i've been advised correctly i should expect mine back this week as it's been sitting on sonys service centres shelf for over 4 weeks now awaiting the firmware upgrade after also being repaired.....
somehow,knowing sony,i doubt this will be the case though......
Old 10-05-2005, 4:12 PM   #27
Zig
Posts: n/a
Must be a case of first in last out. Eight weeks on thursday for me...................
Old 10-05-2005, 6:28 PM   #28
paul1672's Avatar
5,258, Level: 17
yep,must mean 8 weeks on friday for me then mate as i returned mine the very next day after you.......
knowing our luck it'll be a few weeks yet..........
Old 10-05-2005, 6:48 PM   #29
5,398, Level: 17
Apparently, according to Sony service, the firmware upgrade was only finalised and available the week I sent mine back, and they have sent a few others back to dealers too in the last few days - maybe yours!?
Besides mine has got to actually get here and work before I'll be really celebrating.
Old 11-05-2005, 2:41 PM   #30
Zig
Posts: n/a
Discount TV have mine back, I will be getting it on Friday.
I hope.
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
3 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
7 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 11th at 11:30am. Prices include delivery.
