Yes I demoed the HC900 at Nexnix in Horsham. (I think most people on here who have seen it, saw it there!)
It's a godd machine, no doubt about it, however in the end chose the Sony Hs-50 for the following reasons.
1. The HC900 fans are noisier than the sony. They're quiet ish... just not as quiet as the sony.
2. Contrast ratio on the Sony is not only better on paper, but I felt was visible on screen.
3. Because the HC900 is a brighter projector, the black level on the Sony was better. (I have a light controlled room, so I find the HS-50 perfectly bright enough.)
4. Lens shift. Not even vertical, let alone horizontal. My projector has to go high up on a wall because of an arch underneath where it's mounted. So I had to have a machine with lens shift.... Sony wins again.
Now, having said alkl this it sounds like I'm saying the HC900 is bad. I'm not. All those things above (with the exception of 4) were very close run things...
In short, if you can mount the machine centally and DON'T have total light control... get the HC900.
If you can't mount centrally and do have total light control... I think you'll find the Sony better...
Hope this helps...
Regards,
Martin
