30-01-2005, 11:43 AM
#1 (permalink)
Is anyone using a Sony HS20 connected via DVI to their PC?
I have tried all the tips on AVSForum and most of the others. I've installed Windows XP Media Centre Edition from scratch and the best I can get is a 1024x768 window that slides left and right across the 1368x768 desktop.
I even set the new install just to use the HS20 as the single display.
The graphics card is an nVidia FX5200 and I also tried an ATI with the same result.
If I can't get this sorted I shall have to consider selling the HS20!
I have placed a wanted ad to see if a DVI to HDMI cable will solve the problem.
If anyone has this setup working please tell me which graphics card you are using.
Dave
30-01-2005, 11:56 AM
#2 (permalink)
Thanks: Gave 6, Got 21
I got my 6600gt working with a hs20 at 1368*768 using the 71.40 drivers, see the post in the htpc forum. If you use the hdmi socket you can only run 1280*720 and lose the benefit of pixel mapping.
John
VW60, 10ft Screen Excellence Acoustic, Kef Ci9000 fronts and centre, Ci200r rears, Myryad MDP500G6, Arcam P7, SVS Sub, SMS, HTPC, Pronto 3*TSU9400, RFX9600, Russound Multiroom, Squeezebox Duet
30-01-2005, 2:51 PM
#3 (permalink)
Thanks, I can only find 66.93 on the nVidia site. Where did you get 71.40?
Dave
30-01-2005, 3:48 PM
#4 (permalink)
http://www.guru3d.com/ its a beta driver whicch is why its not on the nvidia site.
John
30-01-2005, 7:19 PM
#5 (permalink)
Thanks John, I'll try it later.
Dave
31-01-2005, 11:49 AM
#6 (permalink)
Well I've tried this version and I still can't get full 1:1 pixel mapping.
I'm beginning to think there is something physically wrong with my projector.
If I configure the HS20 as a GBR on the DVI and then configure the PC accordingly I get a full widescreen image from the projector, albeit at the reduced res.
I also found that if I went into PS and selected "Get Info Directly from the projector" it obtained all the details with no error. When I try the same thing with the HS20 configured for a PC connection I get the usual error messages about compatiblity etc and I cannot edit the 1024x768 settings.
I tried modifying the GBR .inf file to suit the PC connection but it still gives me the low res.
When I got the pj it only had seventy odd hours on the lamp. I'm now over 100 and only 4 hours has been used for actually watching something! The rest has been spent trying to get the 1:1 issue resolved!
I have noticed that when the pj goes into GBR mode there is a physical click from inside. This swicthing doesn't occur when using it set to PC.
Dave
31-01-2005, 12:30 PM
#7 (permalink)
Hi Dave,
I think your first probelm is that you need to select PC - digital for pixel mapping.
With the 6600 I used the nvidia custom timings, we didn't have powerstrip installed although I have used it in the past with an ATi card.
This is the thread 6600GT Resolutions - cropped via DVI with exactly the change we made in the nvidia settings.
John
31-01-2005, 1:18 PM
#8 (permalink)
Thanks, I only mentioned the GBR because of it's different behaviour compared to the PC link. All my efforts have been towards getting the PC interface working correctly. I only tested the GBR to see if that was the same, which it wasn't.
I've had a look at that thread and I'll see if I can get some time tonight to test a few things. I'll un-install PS for a start.
Do you just the default plug and play monitor in device manager or do you have a custom .INF file?
Thanks again for your help
Dave
31-01-2005, 1:23 PM
#9 (permalink)
Yes it is the standard plug and play monitor driver. Just make sure that the box, "hide reoultions that this moitor does not support" is unchecked.
AFAIK the video gbr mode has a max res of 1280*720.
I dont think it will matter if powerstrip is installed or not but we didn't need it.
John
31-01-2005, 7:14 PM
#10 (permalink)
Would you be good enough to tell me where I find the Advanced Timings" option?
Dave
31-01-2005, 7:23 PM
#11 (permalink)
Dave
For the 6600 its
display properties>settings>advanced>geforce 6600gt>screen res & refereshh>advanced timing
I Have no idea how similar that is to other nvidia cards.
John
31-01-2005, 8:22 PM
#12 (permalink)
Thanks John, not an option on the FX5200.
Would you recommend I ditch the nVIDIA and buy an ATI 9600SE?
Dave
31-01-2005, 8:27 PM
#13 (permalink)
We know it works reasonably easily with ati and powerstrip.
John
05-02-2005, 10:55 PM
#14 (permalink)
hs 20 via dvi
hello,
I too faced a similar dilemma with my hs20. I was fortunate enough to get some help from someone in this forum.
Powerstrip with my 9600xt card @ a res of 1366x768 with 1:1 mapping has created what I believe to be an amazing image while watching dvd's.
I would suggest searching for powerstrip settings for the hs20 as a good start. Feel free to contact me if you need further assistance.
Good luck.
