Is it a dust blob?
Old 28-05-2012, 9:47 PM   #1
Is it a dust blob?
I bought my Benq w1100 about 2 months ago; after one month (maybe it was there from the beginning, but I have not noticed it) I started to notice like a blob on dark scenes only (I attached 2 pictures). My fear is it is not a dust blob, but something else. Can you help me?
Thank to everybody
PS sorry for my English
Paolo
Old 28-05-2012, 9:50 PM   #2
Thanks: Gave 131, Got 94
Hmmm, looks like a dust blob to me but can't be certain. I'm sure some of the more experienced folk here can give a better answer than me, sorry!
Old 29-05-2012, 9:21 PM   #3
Thanks for your reply; my doubt is that the blob seems almost a perfect circle, is it possible speaking about dust?
Old 29-05-2012, 9:31 PM   #4
kbfern's Avatar
Thanks: Gave 958, Got 1,924
To see if it is dust turn your focus ring fully one way then the other if it is dust it should come into focus as a tint spec of dust.
Old 30-05-2012, 9:22 PM   #5
Thank you for the answer; turning focus ring fully one way the blob comes into focus (and using also zoom ring, with the smallest size is more visible), but the tint is always the same, doesn't change: light grey like the attached pictures
Old 30-05-2012, 9:52 PM   #6
Then it's a dust blob! Not sure what's recommended to remove. I remember my Sanyo recommended blowing at it but better check the manual
