Need advice for outdoor music festival projection
Old 24-05-2012, 9:52 AM   #1
I think I previously posted in the wrong forum category...
Hi everyone and thanks in advance for your help and time.
I have been handed a project for a very big music festival. One of the asks is that I project a looping image onto one of the round tents of the festival, meaning you'll be able to see a looping image on top of it at night.
I'm not concerned with getting the image visible during the day, this is just a night time thing. I'm also not concerned with warping as I know how to deal with that.
What I'm looking for help on is any advice you can give me regarding projectors and the distance/quality they can achieve? The festival organizers will be getting me the projector I just need to tell them which one.
the tent dimensions are attached. Lets say for now that I only want to project onto one side of it, preferably filling the entire side with the projected image.
what kind of projector specs do I need, and how far away does the projector need to be?
thank you very much for helping a visual artist completely new to projecting
Old 24-05-2012, 4:05 PM   #2
Thanks: Gave 33, Got 182
Even though you are Using it at night you still need quite a bright pj. I presume you won't need HD quality so check these out 4000 lumens and upwards Professional projectors I believe some places rent them out too.
Old 24-05-2012, 4:10 PM   #3
thank you.
no idea about throw distances for a tent that size?
Old 24-05-2012, 4:26 PM   #4
Lee Lee is offline
Lee's Avatar
Thanks: Gave 1,225, Got 1,263
You could put some of the projectors in the link posted by Steve into the projector calculator to see what you'll get...
Projection Calculator Pro - Projector to Screen Distance
Old 24-05-2012, 4:30 PM   #5
kbfern's Avatar
Thanks: Gave 928, Got 1,906
The Optoma GT750 is a relatively modest priced projector but has 3500 lumen which is bright by home cinema standards.It throws a very large image from just a few feet.
You could throw a 250" size image from around 12ft although how bright it would be I don't really know.But it will certainly be much brighter than most normal home cinema projectors without going into the super bright ones which will cost considerably more.
http://www.amazon.co.uk/Optoma-Gt750.../dp/B00606RXH6
http://www.projectorcentral.com/Opto...ulator-pro.htm
Old 24-05-2012, 4:46 PM   #6
Could you not try it out before you need it?
Old 24-05-2012, 5:22 PM   #7
omg wasnt even aware there was such a thing thank you so much!!!
Old 24-05-2012, 5:23 PM   #8
Optoma GT750 Projection Calculator - Throw Distance and Screen Size
thank you very much i will be looking at that tonight!! they promised the tent would be completely blacked out which should help with the seeing the image better shouldnt it?
Old 24-05-2012, 5:25 PM   #9
i'm afraid not. I can only try out small test which would be useless... how would i have access to a tent this size? the only time i'll have to do tests is the couple of days leading up to the festival (attended by 60,000 people) and by this point i need to have the equipment at hand, ie, the right projector...
Old 24-05-2012, 6:58 PM   #10
toddy28's Avatar
Thanks: Gave 136, Got 338
What colour will the inside of the tent be ?
Old 24-05-2012, 7:15 PM   #11
Thanks: Gave 451, Got 538
Don't wish to dampen your enthusiasm, but sounds like a project of this size should be handled by a commercial firm with the necessary experience.
Otherwise it could be egg on face time!
Old 25-05-2012, 12:52 PM   #12
colour will be black inside.
@tight You are right and Im speaking to them about changing the idea because what they are asking for will be too expensive as well...
Going to go with an indoor projection on the tent's dome ceiling... problem solved. It's going to be painted black inside to help catch more light?...
thanks for the help again.
Old 25-05-2012, 1:06 PM   #13
toddy28's Avatar
Black won't work , you need light colour to project on
