PT-AE100E, imprinting on the LCD matrix
Old 08-11-2004, 9:46 PM   #1
]mush[
Posts: n/a
Any ideas, contacts etc?
Had loads of friends round the other day and they were all playing with the projector ( bought it may 2002 ). It got left on the a DVD menu screen for about at an hour. I went in and turn off the screen and noticed that DVD menu options had been burnt onto the LCD itself!!
turned it off and checked it the next morning and it had dramatically reduced
but still there if you look for it. Just to top it off, there is also new colour bleeding on the screen, a red colour in the top-left and bottom-right, green in the bottom-left and top-right! This was not their before either so I am at the assumption that the problem is related to the screen burning.
GUTTED
1) has anyone had an issue like this before ? and if so was it the LCD matrix that was at fault?
2) If it was at fault, can anyone provide me with a contact number of how to source a replacement LCD matrix (I can probably fix this myself I think)
3) Any one have an idea how much it would cost for the is replacement part.
4) Does anyone expect this to happen to a LCD projector it has been left on a menu screen for 1 hour? ( FYI, the DVD was Starwars AOTC)
I guess most peeps would just say go and buy a new projector as the AE100E is getting on a bit and there are so many nice new toys, its just that I am really strapped for cash and have to pick the the cheapest option, therefore I would really appreciate any help that your guys give me here...
thanks
Old 08-11-2004, 11:05 PM   #2
11,745, Level: 25
Points: 11,745, Level: 25 Points: 11,745, Level: 25 Points: 11,745, Level: 25
Thanks: Gave 4, Got 243
Here's something...............
http://www.dslwebserver.com/main/lcd-screen-burn.html
That's a weird link (does not seem to want to work), so.....
Join the following two bits together... (cut and paste em into your address bar)
http://www.
dslwebserver.com/main/fr_index.html?/main/lcd-screen-burn.html
Old 09-11-2004, 12:17 AM   #3
Oakleyspatz's Avatar
6,040, Level: 18
Points: 6,040, Level: 18 Points: 6,040, Level: 18 Points: 6,040, Level: 18
Thanks: Gave 37, Got 234
Yes, not commonly know is that LCD can also suffer from screenburn or as the LCD manufacturers call it, 'Burn-in'. Because LCD uses a transmissive rather than DLP's reflective technology. The light passes through the lcd panels and can burn through them with a high enough concentration.
The red staining is a similar problem caused over time by the light burning usually the blue filter first which strengthens the red filter causing the red to dominate the image and can only really be corrected by a new blue lcd panel which is quite costly, but certainly achievable. Contact Panasonic's web site for availability and cost of these blue lcd panels.
Old 09-11-2004, 1:06 AM   #4
theritz's Avatar
12,408, Level: 26
Points: 12,408, Level: 26 Points: 12,408, Level: 26 Points: 12,408, Level: 26
Thanks: Gave 10, Got 31
mush,
Sorry to hear that you have problems.... you might find that the "persistence" that's marking your image could fade with further use... I use a pc which has a sleep mode so if it's left unattended for a break the screen goes blank, so the problem doesn't arise.
Oakleyspatz,
There's lots of news there... Could you explain a little further, would also help if you could tell us whether your advice comes from personal/professional experience.
I've come across blue polariser damage, but it usually results in yellow staining, not red, and mush is suggesting red staining in one corner and green in the opposite crner which usually indicates colour uniformity problem - can be caused by warping or vertical mis-alignment in the optics... Replacing a blue polariser is straightforward, but polariser damage doesn't automatically mean replacement of the LCD panel. I'd be interested to see where availablilty of replacement LCD panels for projectors is covered on Panasonics website - hadn't come across that before......
Sean G.
Old 09-11-2004, 1:35 PM   #5
]mush[
Posts: n/a
Thanks for your feedback.
I have checked out the Panasonic web page and there spares are quite limited i.e. replacement remote or bulb, power cord etc so internal parts are probably a no go for a domestic purchase. Looks like I will have to go through a registered repair centre, :-(
I checked the screen burn today and yes, it seems to be retarding so this is good news!
However the colour bleeding is still present in the corners so I guess the two issues are not related. I must of just picked up on it when I checked out the screen burn issue, as the colour bleeding is discrete ( but now I see it, now it bugs me syndrome!).
Anyone have an idea how the colour bleeding could have happened? Does anyone believe it could be due to overheating and hence possible warping? or given a nasty knock?
I appreciate all the responses.
thx
Old 10-11-2004, 9:58 AM   #6
13,324, Level: 27
Points: 13,324, Level: 27 Points: 13,324, Level: 27 Points: 13,324, Level: 27
Activity: 46.3%
Activity: 46.3% Activity: 46.3% Activity: 46.3%
Thanks: Gave 1, Got 523
As the other posters have suggested, the LCD burn in will almost certainly fade in time.
The colour shift in the corners is most often caused by the dichroic colour filters overheating. This is a common problem - usually the blue filter is the worse affected.
They are usually fairly easy to replace.
Steve
BTW, I think you were underestimating how easy it is to change an LCD panel. The alignment required is measured in microns and I don't believe it's possible without the manufacturers alignment rig.
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
2 prices from
 £149.95 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
7 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 13th at 3:30am. Prices include delivery.
