Originally Posted by Riz_Mini Hi there,
I think your probably referring content recorded in 24/25/30 frames per second? |
That is correct.
Have you tried a Panasonic Plasma, if so enable the TrueMotion engine (not sure what its called) and see if it makes a difference.
Believe TrueMotion is something LG (and possibly others) use. Panasonic has its own set of modes, none of which present a particularly pleasing image.
Thanks for the advice, guys, guess I'll have to simply try a bunch of projectors and see which one doesn't make my head scream.
A shame seemingly no (cheap-ish) projectors have 48 or 72fps modes. Believe that's how they solve flickering, possibly judder, in theaters. I suppose there's a slight difference between a film print and a Blu-ray, though...
