Hi, I just thought id create a separate topic for this as i dont think its too relevant to keep posting in the Panasonic PT-AE700 Reviews topic.
Basically, ive got my chipped (with Xecuter 2 chip) pal xbox connected to my PT AE700E via 1m 75ohm resistance gold plated component leads and official Microsoft High Definition AV Pack. (Chipped to enable progressive scan as by default pal xboxes only run in interlaced mode). Problem is that when displaying in 525p progressive scan mode (films and most games run in this mode when progressive scan is enabled), there are very visible vertical bars all the way along the image, although interlaced and 750p displays fine.
http://www.webthingy.pwp.blueyonder.co.uk/image1.jpg
No amount of tweaking of picture settings or flicker adj will rectify this. At first i thought it was a Vertical Banding issue but upon further investigation looked more like an xbox fault. However, a friend has also got the same model projector and an xbox with the same chip hooked up to his projector with the same brand of cables and he is getting the same problem. Also, tried different cables and a 3rd party HD Pack but result is the same (but with lower quality picture). My friend has also tried a different source (DVD player) using the same component cables and had no problems there.
Im wondering if anyone has experienced similar problems or has a similar setup they could test. It could be a certain model of xbox or mod chip that has this problem as different revisions of xbox use different video chipsets apparently so manufacturer dates of working xboxes would be handy! Hopefully in the next week i'll be able to try 2 different xboxes with the projector to see what happens but any extra info would be useful, thanks!
