| Optoma HD600x Dead Pixels?
First time poster, hoping for some help after finding a problem with my projector. I've had a Optoma HD600x since last September (so less than a year), and I use it pretty rarely, maybe 40 hours of use since buying it.
I used it last night through my PS3 for a DVD and some games, and all was well, no problems, and it turned off fine after a total usage of about 4 hours.
Next day (today!) I just turned it on to find the projected image covered with black squares - which I believe are dead pixels? I switched the test pattern on to white and the black squares are all over the image making it took grainy.
Is this a normal thing to happen? I always thought you might get 1 or 2 dead pixels, like with a LCD screen, after a year or so, but not from none to hundreds overnight? I'm a little annoyed that a projector of less than 1 year and minimal use has suffered this - I'm going to phone Optoma tomorrow to see if its covered in their warranty, which as the projector is less than a year old I can't see how they could argue out of it. Does anyone have any advice in addition to this? Would really appreciate any feedback.
