Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
InFocus Play Big X9
Acer X110
Optoma HD200X
Optoma HD20
Panasonic PT-AE3000
Optoma Pico
 More...Prices updated November 25th at 7:30am and include delivery.
Old 27-04-2004, 2:22 PM   #1 (permalink)
yellowbug
Posts: n/a
Dead pixels / sticking pixels ?
Is the problem of dead pixels or sticking pixels only relevant when you first buy your PJ or can they develop over time? If so, how widespread is the problem, as this may tip the balance for me in favour of DLP. I have not managed to find any info on this elsewhere. It terrifies me that LCD PJ manufacturers won't consider it a fault unless it gets to quite nasty proportions, as it would annoy the heck out of me.
Ade
Old 27-04-2004, 2:27 PM   #2 (permalink)
Kramer's Avatar
Thanks: Gave 5, Got 32
Most LCD pixel defects are there from manufacture. Pixels can fail during use but this is very rare IMO.
DLPs can have faulty mirrors although again, this is extremely rare.
Two options when purchasing an LCD:
1. Buy from a dealer with a pixel check/guarantee
2. Take your chances.
Kramer
My personal opinions expressed here are not necessarily those of the AV Forums or other related websites, but you all know that
Kramer is offline   Reply With Quote
Old 27-04-2004, 2:42 PM   #3 (permalink)
Spasm
Posts: n/a
Dead pixels can either be apparent from the off set as Kramer suggested or develop over time:
They are either seen as "dead" pixels displayed as black and "lit" pixels that are white:
This occurs as each pixel on an LCD screen is made from three separate subpixels—one red, one green and one blue—that when combined form the colours that the users see on the screen. A dead pixel occurs when the transistor that activates the amount of light that shows through all three subpixels malfunctions and results in a permanently dead/ilt pixel.
DLPs can get stuck pixels although this is very rare so I wouldn't let this bother you.
With regards to LCD - most dead pixel warranties follow a simular precesure. Split the screen into nine equal squares. You are allowed up to 8 dead pixels as long as there are no more than one in the central square. Any more and the projector can be fixed under warranty.
Old 27-04-2004, 3:05 PM   #4 (permalink)
Assured Advertiser
Liam @ Prog AV's Avatar
Thanks: Gave 5, Got 688
Dead pixels developing over time are more common than you might think, more likely during the first 6 months or so of use....
With LCD pixel policies you'll find each manufacturer has their own way of doing it. Most have a simple 0.01% tolerance - useless really seeing as that's around 40 pixels on even the lowest resolution PJs!
Then there are the weird rules pertaining to location on screen and in relation to other pixel defects - some manufacturers will accept fault if there are "clusters" of two or more pixels in certain locations and some even go into location of "clusters" in relation to other clusters! IIRC Panasonic take into account location of screen (4x4 grid of inner 4 and outer 12), colour of defect, location in relation to certain other colour defects, and if those defects occur as clusters or not and what their location is relevant to other clusters of a certain colour!!!! Of course if you phone Panasonic up three times in a row and ask for their policy i'll bet you get three different answers
Top Gear in HD - my two favorite things ever finally combined!!
call me: 01892 860801 / e-mail me: liam@progressive-av.com
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Liam @ Prog AV is offline   Reply With Quote
Old 27-04-2004, 5:04 PM   #5 (permalink)
Conspicuous Member
Gary Lightfoot's Avatar
Thanks: Gave 12, Got 377
Sim2 checks all DMDs for mirror function/failure prior to shipping (amongst other things), and combined with a 3000hour/12month lamp guarentee, I believe they're the pj leader for ensuring you get the image you pay for.
Gary.
Gary Lightfoot is offline   Reply With Quote
Old 29-04-2004, 5:51 PM   #6 (permalink)
yellowbug
Posts: n/a
Well thanks for clearing that up then!
Interesting to hear that DLP's can have stuck mirrors too. BTW I am now looking seriously at buying the Panasonic AE500 (although their policy in this regard does sound rather strange, clusters and all that stuff), subject to forthcoming demo. I will be looking out for the vertical banding issue I've read so much about, but then all PJ's seem to have an issue of one description or another!!
Now, over to the DVD player forum to see if I can find out which player is going to give me the dvi output I'll be needing for the 500...
Ade
Old 30-04-2004, 7:35 AM   #7 (permalink)
Super Moderator
Thanks: Gave 465, Got 946
Whilst not wanting to deny what Liam says, the likelihood of a PJ developing new bad pixels after manufacture is honestly quite rare. The thing to do, IMO, is to thoroughly check YOUR projector when you collect it. Get them to use its test modes to show you each of a fully black, red, green and blue image and inspect it for defects. Get one which is defect free from new (they are, mostly) and it will in all probability stay that way.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 30-04-2004, 9:45 AM   #8 (permalink)
yellowbug
Posts: n/a
Sounds like the best bet to me. I haven't been to this dealer before so I don't yet know if their demo room will be light controlled (I doubt it), will I be able to spot defective pixels if there is ambient light?
Ade
Old 30-04-2004, 10:21 AM   #9 (permalink)
it is more tricky but as long as its fairly dary and you can look at it on single colour screnes. most importantly Black blue and white imho as this should show up the most annoying of the pixels lit blue, lit green on the dark scenes and the dead or perma off pixels on the light scene. rmember to look hard before you buy then just enjoy the PJ once you have bought
Mirablo is offline   Reply With Quote
Old 30-04-2004, 12:44 PM   #10 (permalink)
Thanks: Gave 0, Got 5
Anyone know how thorough discounttv are in regards to pixel checks as I see they do a dead pixel check.
zoolap is offline   Reply With Quote
dead, pixels, sticking
