HT300+ NSTC contrast problem
Old 05-04-2004, 9:32 AM   #1
6,176, Level: 18
Points: 6,176, Level: 18 Points: 6,176, Level: 18 Points: 6,176, Level: 18
Thanks: Gave 100, Got 47
Have any other HT300+ owners experienced the following problem, most evident when trying to set up the projector using a THX test pattern disc (such as the one found on Cape Fear Reg1) ?
With NSTC sourced material, the contrast pulses up and down of its own accord every 30 seconds or so. Very evident in dark scenes, and of course blatant using the test disc.
This is REALLY bugging me. Have I got a faulty machine ? Faulty software ? PAL material plays fine...
Old 05-04-2004, 9:57 AM   #2
chips's Avatar
12,617, Level: 26
Points: 12,617, Level: 26 Points: 12,617, Level: 26 Points: 12,617, Level: 26
Thanks: Gave 9, Got 21
I get the same thing with my HT300 when using a progressive feed. It's noticeable on THX Optimiser and on some dark scenes on a few DVDs.
I have read that it's macrovision related. The only cure I've found is to switch to interlaced feed on the problem disks. Fortunately it's only a problem on a small number of DVDs as I prefer using the deinterlacer in my Toshiba 9500 which I think does a slightly better job than the Faroudja in the HT300.
Old 05-04-2004, 11:09 AM   #3
6,176, Level: 18
Aha !
So it IS a general fault, and not specific to me !
Thats very interesting. SIM have just had my projector in their workshop for 16 days, supposedly fixing it. Musical Images stuck it back on the ceiling on Friday and if anything it was WORSE !
SIM themselves are in theory coming to check it in situ soon. If it can't be fixed, I don't want the projector.
I'll report back as and when....
Old 05-04-2004, 11:03 PM   #4
5,667, Level: 17
Points: 5,667, Level: 17 Points: 5,667, Level: 17 Points: 5,667, Level: 17
Thanks: Gave 1, Got 14
dc007,
Which software version are you using ?
And what's your DVD source ? And what are your settings ?
If this were a general fault, I think I would have seen it by now.
I have had no such experience with any 300, 300 plus, 300Xtra or 300 Link that I have demonstrated or sold.
You are most welcome to bring your machine down for a check and a comparison with a 300Xtra with the latest software.
Old 06-04-2004, 7:10 AM   #5
6,176, Level: 18
RTFM,
At work so I can't check, but pj was just updated with latest download, its component progressive from a Denon DV11 (previously from a Pioneer 737). Which settings do you mean ? The sharp/bright/contrast etc has been adjusted using a THX optimiser disc - but it's been kinda tricky to do this correctly due to the contrast pulsing problem...
Old 06-04-2004, 7:55 AM   #6
chips's Avatar
12,617, Level: 26
dc007,
Is this the problem that you are experiencing?
http://www.avforums.com/forums/showt...hreadid=114428
Anything Else R1 Review
For the record, I have an HT300HD running Software Version 2.21, which I believe to be the latest release. DVD player is Toshiba SD9500.
Edit;
This problem has been discussed on AVSForum (USA). It has been suggested that it is a hardware issue and that there is a fix. I haven’t bothered to investigate further as it is only apparent on a few DVDs and I just switch to interlaced on those but am intending to ask for the mod to be carried out when my machine needs a bulb change.
http://www.avsforum.com/avs-vb/showt...ht=fluctuation
Old 06-04-2004, 11:56 AM   #7
6,176, Level: 18
chips,
Those threads do seem to be the exact same problem, yes !
Have just had a call from SIM and they are over on the 15th April to witness it 'in situ'.
I'm sure there's a way around all of this... but I don't have the knowledge/skills to do it personally - thats why I paid big wedge for an install, and thats why I want it sorted !!
Old 06-04-2004, 4:02 PM   #8
chips's Avatar
12,617, Level: 26
That's good news. Let us know how you get on.
I'd better see if I can get mine done too before my warranty expires, if there is indeed a mod to fix this problem.
Old 16-04-2004, 8:41 AM   #9
6,176, Level: 18
UPDATE
Well, Mr Rosler from SIM was over last night and witnessed the problem first-hand. It was still very evident even when linking his own Denon A11, thus ruling the player out of the equation.
He's carted it back off to the factory, hopefully for a cure. If not, here's one punter who will be looking for a refund.... !
I must say, hats off to SIM's 'aftercare'... so far !
Incidentally, he also thought the PJ was running a little noisy, so fingers crossed that might be improved too
Old 26-04-2004, 6:20 AM   #10
chips's Avatar
12,617, Level: 26
Is it fixed? If so, what was the problem?
Old 27-04-2004, 11:52 AM   #11
6,176, Level: 18
Allegedly, its now fixed - in fact, Musical Images are coming over this evening to re-install.... so I'll know for sure within the next few hours.
I believe it need one circuit board or another replaced, something to do with the macrovision... the technical side is all a bit of a blur to me, but I know Alan reads these boards so maybe he could explain... ?
Anyway, hopefully a final update from me tomorrow
If not, it'll be money back time
Old 27-04-2004, 10:49 PM   #12
4,142, Level: 15
Points: 4,142, Level: 15 Points: 4,142, Level: 15 Points: 4,142, Level: 15
Thanks: Gave 2, Got 18
All fixed and fully tested with the THX test patterns and the A11, image solid as a rock! Sorry it took a couple of attempts to solve the problem
A bit surprised you haven't received it back yet, since we sent it back to MI the very next day
We made a little progress in reducing the accoustic noise as well.
Please let me know how you get on?
Kind Regards
Alan Roser
Managing Director
SIM2 UK Ltd
Old 28-04-2004, 7:41 AM   #13
6,176, Level: 18
Hi Alan !
Yes, I've been a little disappointed with Musical images' rsponse times too.... And guess what - they blew me out last night too
Got the call at 5.20 to say they couldn't make the 5.30 appointment, and to reschedule for Thursday.
More than a little cheesed off, as I'd cancelled a work thing in order to be there last night....
So, will now report back Friday....
Old 28-04-2004, 7:11 PM   #14
4,142, Level: 15
Old 04-05-2004, 9:36 AM   #15
5,667, Level: 17
dc007,
Any news ?
Old 07-05-2004, 11:20 AM   #16
6,176, Level: 18
Have been away a few days, but will be putting the machine through its paces at the w/e....
Will get back on Monday
Old 10-05-2004, 8:40 AM   #17
6,176, Level: 18
Things went HORRIBLY bandy over the weekend.
picture started looking like the special effects from Dr Who, whatever the source.
I've had enough.
Old 10-05-2004, 5:40 PM   #18
4,142, Level: 15
I'm sorry to hear that you are still having difficulties with this unit, I am in discussion with Musical Images to solve this problem for you.
Regards
Alan
Old 11-05-2004, 12:14 PM   #19
6,176, Level: 18
I've got to be honest Alan, my faith in SIM2 products and reliability has been rattled by all this. I've got a 30 grand home cinema and I've watched two movies in 6 weeks...
Old 11-05-2004, 6:42 PM   #20
4,142, Level: 15
I fully understand and appreciate your position, perhaps you would be kind enough to contact me via my office email at alan.roser@sim2.co.uk with your phone details and I'm sure we can come to a satisfactory conclusion.
Kind Regards
Alan Roser
Managing Director
SIM2 UK Ltd
Old 29-05-2004, 12:24 PM   #21
Saf
Posts: n/a
Hi dc007
Did you manage to get a satisfactory conclusion to your problems? You haven't posted for a while and I was wondering did they fix your projector or replace it? Or did you have to insist on a refund? If so what are you considering next?
Which DVD player were you using? I was getting the same pulsing problem and my Meridian 598DP was blamed for a while. The pulsing occured in progressive mode with NTSC Macrovision encoded discs such as 'Kill Bill' and 'School Of Rock'. Once you've used progressive going back to interlaced is such a backwards step.
Keep us informed.
Safdir
Old 05-07-2004, 10:31 AM   #22
Saf
Posts: n/a
I was also using video filters (3) between the Meridian 598DP component inputs and the 300+. This did get rid of some other very annoying problems (bending of top of picture) but not the 'pulsing'.
I have actually had a major upgrade. The Meridian 598DP has had an SDI mod fitted and is running through a Lumagen Vision PRO scaler to a 300Xtra via DVI. The picture quality is stunning! I've been too busy re watching all my favourite films to tinker with the set up to find out which stage of the upgrade has been the most worthwhile. It all just works perfectly - thanks to Gordon Fraser.
Saf
Old 05-07-2004, 2:38 PM   #23
Gordon @ Convergent AV's Avatar
41,380, Level: 49
Points: 41,380, Level: 49 Points: 41,380, Level: 49 Points: 41,380, Level: 49
Activity: 4.7%
Activity: 4.7% Activity: 4.7% Activity: 4.7%
Thanks: Gave 984, Got 1,706
Thanks Saf,
The sync stripper Video Filter is talking about is different from the filters we had to use on the component outputs of the Meridian to stop the banding. He's talking about removal of macrovision I believe.
Saf bought a VisionProHDP scaler to allow an all digital pathway from his Meridian with SDI to his new Xtra300 PJ. Got to say it was looking pretty good when I left. Next stage is ISF calibration in a few weeks followed by firmware update to make scaler picture output even better.
Gordon
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
2 prices from
 £149.95 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
7 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 13th at 1:30am. Prices include delivery.
