Quick google revealed: "DVD-player Sony DVP-NS300 r1/r3/r2-Japan don,t have solderless upgrade
(Example: PDA, DESKTOP, IRC, CD - R and etc....) in
variant MULTIREGION, and NTSC and PAL-enable, and Macrovision OFF.
The modification of this player is done only through special
Sony-Data-service-cable and special firm software through plugs
On main-board (plug CN-103) and on IR-board (plug CN-405).
P.S.: NOTE - Besides, on main-board of this player it is necessary to install additional
Components for Pal-enable."
Then again, someone said: "Just to confirm I've just used the one4all universal remote control hack on a uk spec NS300 and it worked a treat, now watching my region 1 dvds"
Some owners have enabled multiregon playback using IR hex codes on Prontos/PDAs or using universal remotes etc. Don't know if this disables macrovision though.
Not in the forums database either.
Think you'll need a little luck.
