| Barco 800 with no picture and no fault
Hello,
I stepped over from a dutch forum where a placed a question about my Barco Data 800. I still have no answer for my problem so I like to try it overhere.
I have a Barco for 3 weeks now. I connected a HTPC on input 5 with a RGBHV cable. Now since I have no picture I connected my Onky DVD player on input 2 with a S-Video cable, but I don't know if this works.
I took out all the prints and checked the components and all solder connections. Wath looked like a bad connection I re-solder, but unfortunatly I found nothing. I also tried 2 deifferent VGA - RGBHV cables, without result.
After placing back the prints, I put the power back on. You here the fans blowing and I hear a vibrating High frequency sound. The red led on the V-board is out. Strange, since there is no source. When I put on a source (DVD on input 2) and select this input, the vibration in the high frequency sound is gone. When I choose an input without a source I see the red led on the V-board comming on, and going of when I select input 2.
I see the end of the tubes glowing, but I here no static sound of the tubes going on. I don't see any red led's burning.
I checked the leds on the power supply. All 7 yellow leds are on and the red (scan fail) is off. When I change the input the red scan fail led blinks, but maybe this is normal.
I checked the red led on the EHT board and it's fine. It doesn't come on when the projector is on.
I see the red led D23 a little bit glowing on the H-Output board. It says in the service manual that this led is on whem the image is to wide.
I tried differnt resolutions on the HTPC using VNC on another PC, but again no results. Resolution is now back on 1280x720 bij 60kHz.
I don't know where to look anymore. I can see no fault, but I still don't have any picture. I turned up the Brightness and Contrast, but stil no picture. I see the controller board responding when I push a button on the remote, so the Barco gets its signal.
Is there anyone who can point me in the right direction. Until now I couldn't find a solution using seach engines.
Hopefully I get it up and running again. It's my first experience with beamers and I'm already hooked.
With kind regards.
Bert
