Help required with Barcovision 508(BV508)[/FONT]
I bought this projector from another AVforums member (off ebay) some 4 months ago and it has worked flawlessly during this time.
Yesterday when I switched it on it refuses to fire up the tubes. When I press the standby/power on button it makes a series of repetitive pulsing sounds and a number of LEDs on what I presume is the power supply board(I have no electronics training at all so I am guessing on this) flash on and off in sync with this pulsing sound. Also the standby/power LED on the back of the machine never goes green as it used to – it stays red.
I should mention that I do not have a fixed set up and have to move it into position each time I want to use it. The last time I used it, it was working fine but then of course after having watched a film I had to lift it out of the way into the corner of the room. I am wondering whether when I did this something has shifted inside.
I have done some reading online about these CRT projectors and have enjoyed this BV508 even though it is video only and hence not considered that desirable. I would love to get it up and running again. Although as I only paid GBP 59 for it I really need a cheap fix or I will have to write it off and look for something else
Video of the problem can be found at:
MVI_1566 - eSnips, share anything[/FONT]
Any advice much appreciated.
