Fitting PJ wires through ceiling
Old 01-10-2009, 8:13 AM   #1
scw scw is offline
3,648, Level: 14
Points: 3,648, Level: 14 Points: 3,648, Level: 14 Points: 3,648, Level: 14
Thanks: Gave 5, Got 4
I posted this over at DIY but have not had a response so thought I would try here.
I am hiding m PJ wires in the cavity above the ceiling and need to make the hole where they come through neater. Above I will put some silicone around the wires so insulation dust does not shower down on me when I’m eating my popcorn, but I need some from of grommet to go under the ceiling room side to neaten things up.
I suppose that ideally I could do with something which splits in half in someway so that it can be fitted fairly tightly around the wires.
What are you guys using?
I also need something to go over a hole in the wall where I occasionally poke some PC cables through and the best I have come up with so far is the socket faceplates which have hairs which you can push out of the way. Is there anything more suitable?
Old 01-10-2009, 8:33 AM   #2
2,872, Level: 12
Points: 2,872, Level: 12 Points: 2,872, Level: 12 Points: 2,872, Level: 12
Thanks: Gave 14, Got 15
Re: Fitting PJ wires through ceiling
I was in Wickes the other day and came across a 'brush lined outlet plate'
Very similar to this, I couldn't seem to find it on the wickes website.
Cut a dry lining box into your ceiling, and screw one of these plates over... a neat solution!
Old 01-10-2009, 9:05 AM   #3
andyr300's Avatar
7,604, Level: 20
Points: 7,604, Level: 20 Points: 7,604, Level: 20 Points: 7,604, Level: 20
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
Thanks: Gave 147, Got 87
Brush plates are the neatest option really as mentioned above.
To tidy up the ceiling, I would install a faceplate onto the ceiling rather than just having the cable coming through loose.
Old 01-10-2009, 10:30 AM   #4
12,535, Level: 26
Points: 12,535, Level: 26 Points: 12,535, Level: 26 Points: 12,535, Level: 26
Activity: 43.6%
Activity: 43.6% Activity: 43.6% Activity: 43.6%
Thanks: Gave 217, Got 317
I'm going to install a 13A socket (fed from a UPS) in the ceiling.
That way the PJ remains powered during the run-down period, it can be switched off when I go on holiday, and can be easily disconnected if I ever have to take it down for cleaning/repair.
Old 01-10-2009, 12:30 PM   #5
2,517, Level: 11
Points: 2,517, Level: 11 Points: 2,517, Level: 11 Points: 2,517, Level: 11
Thanks: Gave 1, Got 6
As stated above, I used one of these..
Wickes *–*Electrical*–*Electrical Accessories*–*Electrical Accessories*–*Single Gang Brush Faceplate
Old 01-10-2009, 4:10 PM   #6
7,290, Level: 20
Points: 7,290, Level: 20 Points: 7,290, Level: 20 Points: 7,290, Level: 20
Thanks: Gave 46, Got 78
Big 'ole.
Old 02-10-2009, 5:05 AM   #7
1,747, Level: 9
Points: 1,747, Level: 9 Points: 1,747, Level: 9 Points: 1,747, Level: 9
Thanks: Gave 1, Got 0
this is a wickes outlet plate i installed
Old 02-10-2009, 9:11 AM   #8
Conspicuous Member
Gary Lightfoot's Avatar
27,928, Level: 40
Points: 27,928, Level: 40 Points: 27,928, Level: 40 Points: 27,928, Level: 40
Activity: 18.2%
Activity: 18.2% Activity: 18.2% Activity: 18.2%
Thanks: Gave 42, Got 519
I used a downlight ring (but without the lamp in it), so it matched the rest of the downlighters in the room. No brush material in it but you didn't see anything unless you shone a torch up there. I don't think a single gang brush plate existed when I built my room (2000) but that's what I'd probably use next time. I would think you could could even paint it to match the rooms decor if it wasn't white.
Gary
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 10th at 10:30pm. Prices include delivery.
