Best CRT for Home Cinema
Old 12-09-2009, 10:59 AM   #1
1,604, Level: 9
Points: 1,604, Level: 9 Points: 1,604, Level: 9 Points: 1,604, Level: 9
Thanks: Gave 2, Got 1
Im a new member to this forum.
Im looking for advice with regard to the following: (no financial constraint)
1. Best CRT for 10-14 foot diagonal screen (Barco??)
2. Distance from screen to projector for above screen
3. Who best to install this in UK
4. Must be able to handle all modern input signals
Thank you
Hendrik
Old 12-09-2009, 2:08 PM   #2
Tom.W's Avatar
5,647, Level: 17
Points: 5,647, Level: 17 Points: 5,647, Level: 17 Points: 5,647, Level: 17
Thanks: Gave 20, Got 115
Re: Best CRT for Home Cinema
Personally I prefer Barcos. A nice 1209s,1208 or 808 model. I would also suggest a smaller screen of 80-96 inches wide. Both projectors can accept all signals including HDMI with the proper adapters. For HDMI you will need an HD Fury.
There are also lots of used Barco parts out there but tube condition is a huge factor to consider.
If you are using PAL instead of NTSC you might have some width issues and might need a scaler.
Old 12-09-2009, 6:07 PM   #3
Roland @ B4's Avatar
9,381, Level: 23
Points: 9,381, Level: 23 Points: 9,381, Level: 23 Points: 9,381, Level: 23
Thanks: Gave 2, Got 39
Hendrik
Are you familiar with CRT setups ?
Have you seen one in action in a proper home cinema ?
Where abouts in the country are you ? Becasue that may affect who is best to install.
I agree with Tom on the screen front that you may be getting a bit big and with a CRT may loose all the quality advantages that you get with CRT.
If you are down south or coming this way happy to show you a 1209 / 808 in action.
Roland
Old 12-09-2009, 10:17 PM   #4
Mad Mr H's Avatar
20,266, Level: 34
Points: 20,266, Level: 34 Points: 20,266, Level: 34 Points: 20,266, Level: 34
Thanks: Gave 604, Got 335
Barco Cine9 with HDMI input module is in my opinion the best you can buy.
With no £ restraint and a big screen then a "Blended" projection system is the very best you can get.
Old 12-09-2009, 10:41 PM   #5
Chris Frost's Avatar
9,048, Level: 22
Points: 9,048, Level: 22 Points: 9,048, Level: 22 Points: 9,048, Level: 22
Thanks: Gave 47, Got 115
Yep, blend is the way to go.
The question then is do you go for a 16:9 screen with a two-projector blend, or do you go for gold with a 2.37:1 screen and three projectors.
Old 13-09-2009, 9:54 AM   #6
9,381, Level: 23
Setting up and maintaining two or three overlaped projectors as your first CRT experience may not be the best option.
Old 13-09-2009, 3:30 PM   #7
9,048, Level: 22
^^^ No one ever said it was going to be easy... but hendrik did say "no financial constraint" so let's have some fun with it for a while
Actually this does raise a very salient topic - running costs.
It's all very well putting in a stunning home cinema, but if there's no money to keep it going then it'll lose its appeal really quickly.
Old 13-09-2009, 5:38 PM   #8
7,476, Level: 20
Points: 7,476, Level: 20 Points: 7,476, Level: 20 Points: 7,476, Level: 20
Thanks: Gave 37, Got 6
Yeh but when did logic ever enter into the frivolous?
Old 14-09-2009, 2:36 AM   #9
1,802, Level: 9
Points: 1,802, Level: 9 Points: 1,802, Level: 9 Points: 1,802, Level: 9
Thanks: Gave 0, Got 8
Actually Chris for a 2.4 scope screen you need only two Pj's , the 4x3 tubes with the 10-20 % overlap give a perfect 2.4 screen image.
nashou
Old 27-09-2009, 7:13 AM   #10
1,604, Level: 9
Originally Posted by Roland @ B4 View Post
Hendrik
Roland
Thanks Tom and Roland
I take your point on screen size. 84 inches could work.
No I am very new to this and is really researching the whole field to learn as much as possible. Mistakes are usually expensive.
I live close to Gatwick, and I have never seen a proper installation. I would love to see the 1209/808 if possible before xmas.
Old 27-09-2009, 7:17 AM   #11
1,604, Level: 9
Mr H
Who is the south east supplier of Barco Cine 9?
I dont think I want to go to the "blended" option at this stage. I was assured that Barco delivers a great picture for home use. Do you agree?
Hendrik
Old 27-09-2009, 6:00 PM   #12
Tom.W's Avatar
5,647, Level: 17
You have a PM.
Old 27-09-2009, 9:10 PM   #13
9,048, Level: 22
For supply then either MMH or Roland would be a good place to start. For installation then Roland; he's the closest installer.
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
2 prices from
 £149.95 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
7 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 12th at 6:30pm. Prices include delivery.
