crt coolant supplier england
Old 01-09-2009, 6:38 PM   #1
1,509, Level: 8
Points: 1,509, Level: 8 Points: 1,509, Level: 8 Points: 1,509, Level: 8
Thanks: Gave 3, Got 0
hi does anyone have a clue where i can buy some crt coolant for my sony kv41 rear projection tv from in the UK?
Old 02-09-2009, 1:04 AM   #2
Tom.W's Avatar
5,647, Level: 17
Points: 5,647, Level: 17 Points: 5,647, Level: 17 Points: 5,647, Level: 17
Thanks: Gave 20, Got 115
Re: crt coolant supplier england
See if you can find a Techspray distributor in the UK. The order # is 1915-16SQ
Projection TV coolant.
Old 02-09-2009, 1:09 AM   #3
Tom.W's Avatar
5,647, Level: 17
Don't think MCM ships to the UK
Projection CRT TV Coolant | Techspray | 1915-16SQ (191516SQ)
Try this place...
http://www.intertronics.co.uk/
dinglydel (02-09-2009)
Old 02-09-2009, 7:54 AM   #4
Roland @ B4's Avatar
9,381, Level: 23
Points: 9,381, Level: 23 Points: 9,381, Level: 23 Points: 9,381, Level: 23
Thanks: Gave 2, Got 39
I have bunch of liquid coupled Barco 8" green tubes that are burnt. The fluid is pretty clear.
Must be about 500ml in each
If you are near Reading happy for you to have them.
Roland
Old 02-09-2009, 2:46 PM   #5
1,509, Level: 8
MANY THANKS FOR YOUR QUICK REPLIES GUYS. Have tried them Tom, but to no avail - it seems in the UK that u gotta throw your tv away when the fluid gets contaminated! Roland, thanks for the very generous offer. Is there any chance i can send a courier to collect? Im in not-so-sunny Devon!
Old 02-09-2009, 2:53 PM   #6
Boris Blank's Avatar
13,407, Level: 27
Points: 13,407, Level: 27 Points: 13,407, Level: 27 Points: 13,407, Level: 27
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 38, Got 78
This is where I got mine Electronix Online
Shipping was dirt cheap as I recall and I received them in about a week. I bought 4 bottles and used three and a bit.
Fluid transfer/removal can be done using a syringe.
dinglydel (08-09-2009)
Old 02-09-2009, 8:55 PM   #7
Tom.W's Avatar
5,647, Level: 17
Is this a glycol glycerin mix ?
As I remember you want about 75%-80% glycol and 25% to 20% glycerin mix.
Most chemical suppliers can ship the raw chemicals.
Old 03-09-2009, 10:19 AM   #8
1,509, Level: 8
dunno mate could be. is that the standard formula for crt coolant? Its a faantastic solution if i can get away with it.
Old 03-09-2009, 5:44 PM   #9
Tom.W's Avatar
5,647, Level: 17
Techspray projection coolant is 75% ethylene glycol and 25% glycerin. The glycerin help both clarity and reduces water absorption through the bellows.
Here is the MSDS sheet :
http://www.mcmelectronics.com/conten...DS/20-4275.pdf
Old 03-09-2009, 7:59 PM   #10
9,381, Level: 23
Hi courier no problem these tubes are all boxed so although bulky no too heavy.
Try the old fluid with Tonic, ice and lime its great.
Old 03-09-2009, 8:12 PM   #11
9,381, Level: 23
"Ethylene glycol tastes sweet, which is why some animals are attracted to it. Many veterinarians are familiar with ethylene glycol toxicity because of the frequent cases that involve dogs or cats who drink radiator fluid."
Also turns out the main use for glycerin medically is as a suppository.
So not so sure if my advice for drinking it is so good.
But like most of my advice you could shove it.......
Old 07-09-2009, 11:13 AM   #12
1,509, Level: 8
lmao Roland. could you email me your address please and i can arrange a courier? many thanks ill let you know how sucessful its been. Thanx for the info Tom, companies are trying to sell me 25 liters of the stuff! Tele's not that big lol
Old 07-09-2009, 8:38 PM   #13
9,381, Level: 23
Email sent
Old 10-09-2009, 12:10 PM   #14
9,381, Level: 23
Quick bit of advice on draining fliud from tubes.
On old tubes , presure can build up because the fluid absorbs moisture.
If your tube does not have a rubber (silicon) expansion chamber or bellows then there is a real danger that the pressure can build to either create a leak or the glass to crack.
It is therefore important to allow an air bubble if your tube does not have such an expansion chamber.
The two tubes that are on their way have rubber bellows and you will see because the bellows compress easily that they are not under too much pressure. The earlier versions of these tubes had a coil of plasitic tube to allow for expension.
I recently drained one of these. When I cut the plasic tube the jet shot about 20ft across the patio. (the very first one hit the ceiling)
My advice is do it over an old cloth if possible outside or in a garage (minding the obvious dust contamination etc) and wear goggles and gloves.
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
2 prices from
 £149.95 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
7 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 12th at 7:30pm. Prices include delivery.
