Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
InFocus Play Big X9
Acer X110
Optoma HD200X
Optoma HD20
Optoma HD700X
Panasonic PT-AE3000
 More...Prices updated November 24th at 6:30pm and include delivery.
Building my own floating wall M.D. Klapwijk Home Cinema DIY 102 20-11-2009 5:55 PM
For Sale : Venturer Portable DVD Player with 8" Screen jonoefc71 DVD and Blu-ray Player Classified Adverts 5 01-10-2009 3:35 PM
grey screen in a light controlled room? Ellispa Projector Screens 18 03-09-2009 7:55 PM
Steering wheel mount (not seat) Bruvva PS3 263 01-09-2009 11:57 AM
Sony Wega KDF-50e2000 screen issue TurdFerguson Rear Projection Televisions 3 17-08-2009 12:20 PM
Old 17-08-2009, 12:44 PM   #1 (permalink)
Thanks: Gave 4, Got 0
Wall Mount Brackets for Screen
Hi All,
Am looking for some "L" shaped wall brackets to hold a screen about 12" away from the wall so that it falls in front of the TV but am struggling to find any.
Can anyone help?.
Chris
chris.tarry85 is offline   Reply With Quote
Old 17-08-2009, 3:48 PM   #2 (permalink)
Thanks: Gave 1, Got 16
Re: Wall Mount Brackets for Screen
hi
i had the same problem and ended up using "u" brackets from B&Q , them come in all sizes all the way up to 24" I think.
wilfy is offline   Reply With Quote
chris.tarry85 (17-08-2009)
Old 17-08-2009, 4:55 PM   #3 (permalink)
Thanks: Gave 104, Got 73
i used some microwave wall brackets (which i conveniently found in the shed) I reckon that they are about 30cm away from the wall so the screen clears the fireplace. Plus they are solid as a rock - wall is more likely to fall down rather than the bracket
Have a look on ebay or argos or something if this helps
Barry_ is online now   Reply With Quote
Old 17-08-2009, 5:41 PM   #4 (permalink)
Thanks guys, these look to be pretty good, adjustable too.
Buy Set of 2 Silver Wall Mounting Brackets. at Argos.co.uk - Your Online Shop for .
Did you have to drill the ends of yours to mount the screen on?
Old 17-08-2009, 8:52 PM   #5 (permalink)
Yes - my brackets had one hole on each - drilled extra hole and used some spare bolts which came with my projector mount (i didn't use the extended section - but if you do i would drill through and bolt together as well - the stronger the better) best advise would be to view the item at argos before buying just to make sure you happy with them
brackets, mount, screen, wall
