Hi yes a VPH-1271 guru is here to the rescue.
Re-solder all the transistors bolted to the heatsinks on the very top 2 circuit boards you see when you take the lid off, you may / have to take the boards right out / off the hinge metal frame to get to all the legs on all of the devices due to metalwork being in the way.
These ALWAYS go if they have not been done before so this is the first thing to check / do.
Don't take the heatsinks off, leave them attached to the boards / devices but handle the boards with care as they could snap.
The legs over time have gone dry jointed and the intermittent connection they are now making is going to cause lots of issues like you have.
E and DC boards are what the 2 boards are called.
Once these have been re-soldered this generally cures most if not all faults and PJ goes on to last another 16+ years.
Check this website out, it’s got pages showing the boards.
John Mears Dot Co Dot UK click on the green photos link at the top of the text and they are right down the bottom.
This guy does repair these boards as well if you don’t want to do yourself.
Hope this helps
