Originally Posted by Chris Frost There's nothing lit on the protection board...The tubes are lit...There's a white line across the middle of the screen...
It sounds like a problem with the vertical image amps but I'd have expected the projector to go into protection mode.
You said you've been in and twiddling to set up the projector. I'd start by resetting the convergence controls (or better still - use the convergence bypass switches) and restart the projector.
If you get your picture back - albeit out of convergence - then it's a setup issue. You've overdriven something on the convergence board. |
My 350 is a bit older and has jumper pins. I have not got many jumpers but
i have done the bypass on a crt at a time with no joy.
I have set it up a few times in a few different venues
Vertical image amps ,they sound like the place to look. Any idea where they are or if there is a test point for me to put a scope on to see the sawtooth.
Thanks for your help
