| Re: Is 6ft viewing distance too short for a projector...
The projectors lens throw ratio, distance to screen / width of image it can project, will be a limiting factor, along with the projectors offset limiting placement. You may find a dlp projector too bright - rainbow effect inducing on a small screen, and might want to use a greyscreen or neutral density lens filter. But dlp also have very good pixel fillfactor enabling you to sit closer before the screen door effect of pixel structure is visible.
I find pixel fill factor to be the image quality deciding factor and angle/arc of vision the comfort deciding factor. I have a darkchip3 dlp and happly sit just over 1xscreen width away. Most pros seem to recommend 1.5xscreen width. It also depends on your visual acutity, what the resolution of the display is, and the source material being displayed: below par standard defintion like some digital tv to good standard defintion dvd to high defintion, and for standard defintion how good the re-scaling is.
To give you some idea of viewing distance - screen size.
Seat in the middle of a theater is about 50 degrees. (1xWidth)
THX recommended viewing angle 36 degrees (1.5xWidth)
SMPTE recommended minimum viewing angle 30 degrees
THX backrow seats minimum viewing angle 26 degrees
