3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Optoma HD200X
Sanyo PLV-Z700
Optoma Pico
Optoma HD65
Optoma HD200X
Sanyo PLV-Z700
Optoma Pico
Benq W1000
Panasonic PT-AE3000
Optoma EP721i
Epson EMP-TW700
Toshiba TDP-S25U
Optoma ES522
 More...Prices updated November 8th at 3:30pm and include delivery.
Is anyone's projector being affected by the extremely hot weather? Bert Coules Projectors 13 04-07-2009 7:33 AM
Projector lamps Pecker ISF Calibration 6 03-07-2009 9:41 AM
Options for connecting projector to av amp? jinjer Projectors 3 03-07-2009 8:38 AM
Old 03-07-2009, 8:18 AM   #1 (permalink)
jinjer's Avatar
Thanks: Gave 1, Got 1
Will my projector be stable enough?
Hi guys,
I'm on the cusp of buying a new Infocus IN83 for the cinema room (as mentioned in my previous thread).
Ultimate solution is to mount it on the ceiling, but this is going to involve some serious DIYing! In the meantime I was going to sit the projector on top of a plant-stand (about 4' high). Will this be ok or will I get too much vibration from the machine and, therefore, a wobbly picture?
Cinema: TH42PX60. Panasonic BD35. SkyHD. Onkyo 875. Revel F32s. Revel C32. Eltax Bi-polars. BK200.
Music: Cyrus CD8x, DAC-X, PreXvs, X-Power. Nordost Blue Heavens. Chord Odyssey 4s. Revel F32s.
jinjer is offline   Reply With Quote
Old 03-07-2009, 8:53 AM   #2 (permalink)
Thanks: Gave 26, Got 12
Re: Will my projector be stable enough?
I have a (vastly inferior ) HD80 and initially sat it on a wobbly old chair for a couple of days before mounting it on the ceiling with no problems.
It'll be fine as long as you don't knock the stand over.
Use the Optoma projection calculator to figure out where to mount it on the ceiling but DOUBLE CHECK by physically holding the PJ in place to check the zoom range will fill your screen size.
namastebuzz is offline   Reply With Quote
Old 03-07-2009, 9:06 AM   #3 (permalink)
Thanks: Gave 53, Got 145
Originally Posted by jinjer View Post
Hi guys,
The Infocus IN83 is reported to be an excellent DLP projector, but in common with most DLP projectors it is not very flexible in its placement due to having no lens shift function. Unfortunately you will have to place it on a low table, below the height of the bottom of the screen or inverted above the top of the screen , so it will not work on your 4' stand.
jacko5 is offline   Reply With Quote
Old 03-07-2009, 9:07 AM   #4 (permalink)
jinjer's Avatar
It won't be a problem as the bottom of the screen will be higher than 4' from the floor .
Old 03-07-2009, 9:11 AM   #5 (permalink)
D'oh!
Good point Jacko I didn't notice it was an Infocus
Yeah it'll have to be either below or above the screen to work properly though with tilting it and maximum keystone you could have a temporary solution I guess?
projector, stable
