Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD200X
Optoma Pico
Epson EMP-TW700
Acer X110
Panasonic PT-AE3000
Optoma ES522
 More...Prices updated November 22nd at 12:30pm and include delivery.
Projector lamps Pecker ISF Calibration 6 03-07-2009 9:41 AM
Old 02-07-2009, 11:21 PM   #1 (permalink)
Bert Coules's Avatar
Thanks: Gave 8, Got 12
Is anyone's projector being affected by the extremely hot weather?
My Sanyo Z4 suddenly went dead tonight, after having been on barely thirty minutes. I can't check until tomorrow, but I'm hoping it's just the thermal cutout clicking in (or out?) as has been discussed here before now, when I and others were convinced that the bulb had blown.
Or of course it could actually be the bulb...
I just wondered: has anyone else had specific overheating problems in the current heatwave?
Bert
Bert Coules is offline   Reply With Quote
Old 03-07-2009, 10:14 AM   #2 (permalink)
Thanks: Gave 45, Got 8
Re: Is anyone's projector being affected by the extremely hot weather?
Mine was OK last night - from about 8.45 pm. It's not a Sanyo though, and it doesn't stand in a place where it could get hot.
Ken42 is offline   Reply With Quote
Old 03-07-2009, 10:23 AM   #3 (permalink)
Assured Advertiser
Alastair Collie's Avatar
Thanks: Gave 48, Got 417
Bert
Morning
It could be heat related especially if the projector is ceiling mounted as this is going to to the warmest part of the room. Certainly we've had cases where amps in cabinets have triggered the thermal cutout and I guess some rooms at the moment are going to get very warm especially those with limited ventilation. I guess you will establish whether it is the thermal cut out by moving it to a cooler or better ventilated area and leaving it on for a while but as you say it may be the lamp. Fingers crossed its the thermal cut out and you don't have to stump up for a new lamp.
Regards
Alastair
www.kenthomecinema.co.uk www.subsonicsounds.co.uk
Proud to be be supporting the AVForums as an Assured Advertiser
Home of the FrontRow Home Cinema Seating
Alastair Collie is offline   Reply With Quote
Old 03-07-2009, 10:25 AM   #4 (permalink)
Thanks Ken and Alastair. My Z4 is well-ventilated all round, but yes, it is ceiling mounted (though right-side up, on a hung shelf) and the thermal cutout has tripped before in hot weather, so I'm hoping that's all it is this time.
To reset it you have to open the case and partially remove the main PCB. (At least, I don't think it resets itself as it cools, but I'll check before I start undoing screws). It's a bind of a procedure but as Alastair says, a lot better - and a lot cheaper - than having to replace the bulb.
Bert
Old 03-07-2009, 11:24 AM   #5 (permalink)
Conspicuous Member
Pecker's Avatar
Thanks: Gave 1,623, Got 1,155
Just a thought - they have projectors in southern California where our current 'heatwave' is probably a pretty average autumn week.
I don't think they can have too much trouble with exploding lamps over there, or we'd have been sure to have heard about it.
Steve W
Pecker is offline   Reply With Quote
Old 03-07-2009, 11:51 AM   #6 (permalink)
Thanks: Gave 117, Got 257
Steve W
I'd have guessed that air conditioning is pretty much standard over there though.
My cinema room has been like a sauna recently so I'm off out to buy a basic air conditioning unit this weekend, don't want to burn the polarisers out on my AX100.
JVC DLA-HD350, Pioneer PDP-4280, 60GB PS3 (UK), Humax 9200, Humax Foxsat, Denon 2307, Mordaunt Short 309i sub, 905i centre, 2 x 906i front floorstanders, 2 x 904i rears, 2 x 302 rears
stuartbrown21 is offline   Reply With Quote
Old 03-07-2009, 11:51 AM   #7 (permalink)
Thanks: Gave 124, Got 982
I haven't put mine on since last Friday. My room is already very hot, I don't need the PJ adding more heat into the room. It is a bit cooler today but will wait until next week until I will put it on again.
Some PJ's have a high altitude setting. This will make the fan turn faster and hopefully run a bit cooler but make more noise.
nwgarratt is offline   Reply With Quote
Old 03-07-2009, 2:15 PM   #8 (permalink)
Thanks: Gave 88, Got 16
Bert
What temperatute is it when the Sanyo cut out? I've a Z4 and never experienced a cut out before.
Projector: Sanyo PLV Z4 | Receiver: Onkyo 605 | Speakers: Canton 102 |Screen: Slimline R231130W 100"| DVD Player: PS3 Remote: Harmony 885
bravogolf is offline   Reply With Quote
Old 03-07-2009, 2:20 PM   #9 (permalink)
Thanks for the further replies.
"Before"? So has yours cut out recently too? I couldn't tell you what the temperature has to be to trip it, I'm afraid, but it's certainly happened to mine two or three times in the past. I haven't checked yet to see what the cause of the latest shut down was.
Bert
Old 03-07-2009, 6:50 PM   #10 (permalink)
Jeff's Avatar
Thanks: Gave 75, Got 247
They also have much bigger rooms which also helps a lot. I went for a proper installed air con system about 5 years ago. I'm really glad I did, the cinema is now the coolest room in the house.
The opinions expressed herein are not necessarily those of AV Forums, not necessarily mine, and probably not necessary.
Jeff is offline   Reply With Quote
Old 03-07-2009, 7:47 PM   #11 (permalink)
Thanks: Gave 41, Got 23
Not had any probs. Try setting your bulb to low power mode and switching the fan to high. Thats what is did with my sony hw10
sloany1979 is offline   Reply With Quote
Old 03-07-2009, 8:04 PM   #12 (permalink)
Good news: this afternoon I tried the projector and it started up with no problems, bulb and all. It's cooler tonight, so I'll see how things go.
Sloany, the bulb's been on the low power setting since it was new; I'm not sure about the fan, but I think that's on low, too. If my viewing comes to a premature end tonight, I'll try adjusting it tomorrow.
Thanks to all.
Bert
Old 04-07-2009, 7:26 AM   #13 (permalink)
Thanks: Gave 5, Got 0
You might want to look at the reply I have posted about the hd700x. I made a fully adjustable stand quite easily that saving me doing the whole ceiling mount thing.
Optoma HD700X Fault?
Matt
mgswills is offline   Reply With Quote
Old 04-07-2009, 7:33 AM   #14 (permalink)
Matt, thanks for that, but I have no problems with my ceiling mount itself, or with removing the projector from it and replacing it in the correct position. When I said that resetting the cutout was a bit of a bind, I simply meant opening the case and partially removing the PCB.
Bert
affected, extremely, hot, projector, weather
