Quick note - need to go to work!
For SOFTWARE blending
You need to "overlay" a mask on the video output......
the issue is that the tripple head does not allow for this......
What you have is ONE output that is then split into three, rather than three outputs.
The systems I know of all overlay a mask on a single output.
Is there any budget for this ???
VLC is a player - SO aybe you would stream the current output into the player.
Did you know that to do what you are asking would have cost £30,000 about four years ago
I have the price down around £4000 for a 3 way blend with hardware.
What you are trying to do in software is fairly difficult, Im still trying to find the one option that might work for you..............I have lots of old data to go through......
What is the resolution you are sending to the tripple head unit? and then resolution to each PJ? Whats you screen size?
