hmmm.
I was all set to buy a matt white screen, something like the sapphire parklane 106".
However having just received my pj and fired it up, at night with no lamps on, the whole room is lit up with reflections. all three walls in fact plus ceiling. Whilst its not as bright as when you turn a lamp on the room is still illuminated. i dont know if this is normal or not?
The walls are cream coloured and the ceiling is white as here:
and here:
The whites and colours look great to me and the blacks in the centre of the screen look fine. However at the sides they look washed out and a light grey colour.
I assume the reflections are doing this.
1. I don't know if the black borders on a white screen will help reduce this a bit? OR is this just something i have to expect- its by no means terrible but i find myself playing with the brightness setting on the pj to just try and get it a bit better
2. If not, what screen am i best off going for to help combat this in terms of screens gain/contrast?? And what are the disadvantage of using a type that you suggest-theres bound to be some i expect!
The room itself cannot be altered with felt or anything.
thanks
mark
