Electric Projector screen mounting???
Old 24-02-2009, 10:36 PM   #1
1,238, Level: 7
Points: 1,238, Level: 7 Points: 1,238, Level: 7 Points: 1,238, Level: 7
Thanks: Gave 1, Got 2
I'd like to mount my electric screen above my fire place, has anyone any experience of this, any problems etc??
thanks in advance
Old 24-02-2009, 11:13 PM   #2
Leej's Avatar
9,349, Level: 23
Points: 9,349, Level: 23 Points: 9,349, Level: 23 Points: 9,349, Level: 23
Activity: 8.4%
Activity: 8.4% Activity: 8.4% Activity: 8.4%
Thanks: Gave 860, Got 971
Re: Electric Projector screen mounting???
Moved to projection screens
Old 25-02-2009, 12:45 AM   #3
AV Nik's Avatar
4,975, Level: 16
Points: 4,975, Level: 16 Points: 4,975, Level: 16 Points: 4,975, Level: 16
Thanks: Gave 45, Got 106
Originally Posted by Robsony View Post
thanks in advance
Hi Robsony,
If you still use the fire, the heat will probably damage the surface permanently. The minimum damage would occur over time as the heat softens the surface allowing it to stretch and warp.
Once the surface is heat damaged, the warranty is void.
If you have no fire in use, apart from some screen cases being wider than the average chimney breast, you should have no problems installing it especially if you have a screen with easy install brackets that can mount anywhere on the case. A screen with fixing points at each end of the case may be a little tricky if you have no beam above the same place you want to place the screen but the detachable easy install brackets can fix to the chimney/brick and then the case/screen fixes to them.
Hope this helps?
Powered by
 Latest popular product prices
Celexon screen Manual Profession...
1 price
 £74.98 Click to show/hide the offers
Celexon Table-top screen 102 x 76cm
1 price
 £108.98 Click to show/hide the offers
Kensington NOBO - Projection scr...
1 price
 £106.79 Click to show/hide the offers
Dell Nobo 2000 X 1513mm Projecti...
1 price
 £139.20 Click to show/hide the offers
1 price
 £154.98 Click to show/hide the offers
1 price
 £146.57 Click to show/hide the offers
WS Spalluto WS-S Screen Fabric -...
1 price
 £169.98 Click to show/hide the offers
Celexon screen Electric Economy ...
1 price
 £204.98 Click to show/hide the offers
 Updated February 13th at 1:30pm. Prices include delivery.
