hi mate
welcome to the joys of planning your first ever av room ... a constant journey of tinkering, replacing, upgrading etc btw ... you have been warned!
in terms of your setup, i am doing upgrading now on the visual side of my setup namely new pj and screen so sort of in the same boat as yourself
the advice given to me in terms of my new setup was to go Anamorphic and opt for the 2.35:1 screen ratio. Most HD material (Blu Ray) is using this format... the size of your room is not a million miles to what my room dimensions are and this is the route i am going.
if watching movies is the main reason in using your dedicated room 2.35 is the way to go ... i use my room for sports (footy on sky etc) as well but have accpeted that i may loose some quality when viewing this in future ... if you plan to watch alot of tv, sports etc as well u may be advised to stick to the 16x9 setup that is the current trend
in terms of screen size i have got ordered for me a custom made A series fixed frame from Beamax (2.35 is a custom build on this type of screen from beamax btw) 290cm viewable (300cm total width) with a 1.2 gain
if you are creating a dedicated h.c. why spend the extra funds on an electric screen? get yourself a decent fixed frame (as above) and use any savings you have for other kit needed for your room. what will the electric screen do for you if its going to be a dedicated room?
Unless of course you want electronic masking therefore check out carada.com and their masquerade solution but these are expensive gimmicks in my opinion ... NB i have took loads of advice on this and feel its a heck of money to spend just to get rid of borders. if money is no object then of course go for it
this is my advice of course and is the road i am going down ... it justs adds to the expense IMHO
this might help you in determing where to place your pj - i'm changing to a jvc hd350 and purchasing a prismasonic lens to carry out my image change (cinemascope). in order to do this i think my pj will be mounted around 4m from the screen to fill this screen ... so you should have something similar in terms of distance to play with ... not sure what the panny needs in terms of throw to fill this size of screen best letting other owners tell u
u can spend crazy sums of money in doing this. everyone will be able to give advice and say this and that; but the advice given to me was keep it simple, get a good fixed frame screen, decent pj and an anomorphic lens system within my budget and you will be OK. best thing is determine a budget and stick within that otherwise u'll shift from pillar to post
hopefully u get something from this post and no doubt others, but good luck and keep us posted on your thoughts.
at this moment my room is getting redecorated and prepped for the new kit ... in the next few wks i should be in a position to provide further info, as i am waiting on screen and lens kit to be delivered and for installation work to begin
ENJOY (if you can)
Originally Posted by Aminator I got the keys to my new house today and am looking at making the lounge a dedicated cinema room..
However I know nothing about screen sizes vs throw of the PJ
The room dimensions are
3.65M wide x 4.34M long
The PJ I am probably looking at is the Panasonic Panasonic PT-AE3000
Now the problem is I want a flush mounted electric screen (wife friendly)
which I have found here: Sesame Screen 16:9
BUT..the formats are all 16:9 and the PJ can display in Cinemascope format2.35:1
Should I take advantage and get a screen to compliment this or stick to a 16:9 screen ? and if so is there anywhere that manufacture a flush fit 2.35:1 electric screen ?
Im really lost when it comes to this as its my first foray into PJ land
Thanks  |
