I just went back over my readings for my recent calibration on my AE3000 and Beamax screen. I use minimum zoom for 16:9 viewing on my 2.35:1 screen (ie the dimmest, but highest contrast). With 100 IRE full field test pattern I measured 5.1fL off the screen using my eye-one LT probe. This seems low even given the size of my screen and that Cinema 1 is known as being a 'dim' mode, though more accurate than 'Normal' or 'Dynamic'.
I compared this to Cine4home's review that gave 300 lumens for minimum zoomin Cinema 1 mode and eco lamp setting. Using some calculations provided IIRC by Gary Lightfoot I created a spreadsheet that works out fL and it gave me 15.8fL assuming the screen really is 1.5 gain.
My PJ has 130 hours on it, but even assuming a 20% drop in brightness that would still equal 240 lumens which gives 12.6fL, still a long way from my measured 5.1fL. I realise that an eye-one LT isn't the most accurate device, but I would have though it wasn't under reading by 50% or more, so it makes me think that my 1.5 gain screen is no more than 1.0 and the rest of the difference could be down to tolerances between my AE3000 and the tested example, plus errors in the eye-one. Kind of disapointing though and to back it up I feel the image isn't bright enough, which strangely effects the dark scenes. I suppose I could have been wrongly supplied with the 1.2 gain version; I'd have no way of checking this though apart from being told that the 1.5 gain has a black backing (mine has).
