| Cinescrew V5 V6 HELP need motor??
i got my and assembly it yesterday have test it and decided to use the harmoony 555 for it, all goes ok until i need to make an change on remote because of sound and decided to stop the screen, it stops in the midle of total length, them i push up buton and it does nt go up, same for down, it makes some noise, guess motor but won t move, today i try again and it won t move i make a litle push on it when use down boton and it start to move i was happy it was back to normal, but after goes down it wont go up...and until now without suceess...i push UP and it makes the same noise of motor but donw go...i do beliave it can be arrange as it wont go down and them goes, but is always easy to go down than up
will apreciat help as i can see tv only movies with projector and is very bad when you pay so much for it
for the ones who intend to buy it arrive with some small damages y can t see i can because i know where they are but i will inform the seller of it, but i would like to know if it is working or not well to request the warranty for it
Could it be the motor?
anyone know how to change it?
