Originally Posted by simon123 I need a flush mounted floor projector screen around the 110"-120" size.
The room is very minimalist, so a fixed screen is out and the ceiling above is at two levels so I cant sink into the ceiling.
a link would be great.
cheers |
All fixed screens are pretty slim, if you wanted to make is appear a little more designer you could build out the sides to meet the edges of a fixed screen with MDF or plsaterboard. Wall colours are also a serious consideration for a Cinema room
