What is the best quality 2.35 ratio UK made screen?
Old 22-01-2009, 3:47 PM   #1
10,249, Level: 24
Points: 10,249, Level: 24 Points: 10,249, Level: 24 Points: 10,249, Level: 24
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 192, Got 82
I was looking to get a Carada brilliant white 1.4 gain screen when my room was ready but the $/£ rate is not favourable and seems to be getting worse by the day. I would also like to support the british worker at the moment so..
I am wondering what is the best quality british made screens are. I am looking for fixed 2.35 ratio one with gain and around 10 foot wide.
thanks
Darren
Old 23-01-2009, 5:17 PM   #2
stubie_do's Avatar
12,310, Level: 26
Points: 12,310, Level: 26 Points: 12,310, Level: 26 Points: 12,310, Level: 26
Thanks: Gave 1, Got 34
Re: What is the best quality 2.35 ratio UK made screen?
Well that certainy narrows it down from 2000 down to about 2.
DRH Screens
Harkness Hall
and now I'm struggling to find another one.
Help anyone?
rigman (24-01-2009)
Old 23-01-2009, 7:39 PM   #3
Conspicuous Member
Gary Lightfoot's Avatar
27,965, Level: 40
Points: 27,965, Level: 40 Points: 27,965, Level: 40 Points: 27,965, Level: 40
Activity: 19.6%
Activity: 19.6% Activity: 19.6% Activity: 19.6%
Thanks: Gave 42, Got 520
What are you like at DIY? You can make a wooden frame and stretch/staple some screen material over it like I did. I made a black velvet border for it and some side masking curtains all from the same material, and it doesn't cost the earth. The screen material is the most costly part but the rest will be quite cheap overall.
Gary
rigman (24-01-2009)
Old 23-01-2009, 10:59 PM   #4
stubie_do's Avatar
12,310, Level: 26
Yes that was it "Lightfoot Screens"
Old 23-01-2009, 11:40 PM   #5
Conspicuous Member
27,965, Level: 40
Activity: 19.6%
LOL
Delivery is extra of course
Old 24-01-2009, 9:32 AM   #6
10,249, Level: 24
Activity: 1.9%
Gary
I am not that bothered too much about cost.
Its just that with the exchange rates I feel like I am paying more for something that is worth much less if that makes sense. It was much cheaper 6 months ago. Buying British would mean I am probably paying the same now as I would have done 6 months ago.
However if the British material is not up to the same spec as the US screen material then that would it would be foolhardy and I should just bite the bullet.
Good idea on the diy option I will be building a screen wall in the new room. I have just bought all the wood for it. I have spent the last 3 weeks bulding frames for soffits and columns.
What material did you get Gary.
Old 24-01-2009, 7:50 PM   #7
Conspicuous Member
27,965, Level: 40
Activity: 19.6%
I think most companies will make you a 2.35:1 screen, and will charge the cost of the next size up 16:9 screen, so try contacting people like Beamax and see what they can offer.
I used Draper M1300 material because it measured at 1.25 gain in comparison to Stewarts ST130 material which was 1.3 gain, but the M1300 was much cheaper (£80 for an 8ft wide 2.35:1 screen).
Gary
Old 24-01-2009, 8:36 PM   #8
CinemaChap's Avatar
9,005, Level: 22
Points: 9,005, Level: 22 Points: 9,005, Level: 22 Points: 9,005, Level: 22
Thanks: Gave 29, Got 43
I use a DRH screen in my room, very please with it.
Old 06-02-2009, 12:06 PM   #9
10,249, Level: 24
Activity: 1.9%
Well despite my patriotism I have decide in the end and odered a 128" diag 2.35 ratio screen from Carada which is being built as we speak
Will not be able to use it for a couple of months until my new room is completed but gives me something to look forward to.
Now looking for a reasonable price anamorphic lens
Old 06-02-2009, 7:53 PM   #10
nobby's Avatar
4,759, Level: 16
Points: 4,759, Level: 16 Points: 4,759, Level: 16 Points: 4,759, Level: 16
Thanks: Gave 18, Got 9
looking into buying one myself, not sure what to do ... looked into carada as well, can i ask will you have to pay VAT on the item when it reaches these shores as well?
Old 07-02-2009, 11:57 AM   #11
10,249, Level: 24
Activity: 1.9%
Yes probably but it still works out cheaper than some of the screens from the uk supliers at the size I wanted.
I also looked at getting a SMX screen but when I was told the price 4K I changed my mind
Carada have an excellent reputation as being very good screens so I just bit the bullet. I think it is 5% inport duty and then vat.
Old 08-02-2009, 3:36 PM   #12
nobby's Avatar
4,759, Level: 16
ok
good stuff, will look into this
have you received your carada yet?
if so what was the lead time in terms of production and delivery?
Old 08-02-2009, 6:42 PM   #13
10,249, Level: 24
Activity: 1.9%
The build time is 3 working days. I have heard from order to delivery takes 8 days although I will believe it when I see it.
I bought the 117.9" wide version which made it an oversized parcel. This means they had to do a different courrier service which was more expensive
Had I gone slightly smaller then it would have been sent economy but I did not want to go any smaller so I did not compromise my 16:9 viewing.
My new room will not be done for a couple of months so I am not in any real hurry.
I will let you know when it turns up.
Old 14-02-2009, 10:31 AM   #14
10,249, Level: 24
Activity: 1.9%
Received a call from a courrier yesterday and a bill for £123 for import duty, vat and a backhander fee.
They are delivering it on Monday So not too bad 12 days from order to delivery.
Hope it lives up to the hype
Old 14-02-2009, 2:27 PM   #15
nobby's Avatar
4,759, Level: 16
nice one mate
12 days is not too bad considering
bit of a kick re taxes ...
i was on my way to purchase a carada criterion 120" 2.35 screen when Gordon Fraser contacted me and has ordered up a custom spec A series fixed frame from Beamax on my behalf ... total cost around 850 for me inc postage ... similar size of screen to the one i was to go with carada, but it has a 1.2 gain in screen and i have a wait time of 3-4wks ... but if GF is happy then i am happy ... he has to do the calibration work on my system so i may have to wait on his services anyway!
keep us posted on your progress, i will be sure to discuss mine, and stick a few pics up where possible
very interested to see what this new viewing format will being to my room/cinema experience
Old 14-02-2009, 4:48 PM   #16
10,249, Level: 24
Activity: 1.9%
I will not be hanging it on the wall for a couple of months at least as I am waiting for an extension to be built.
I will be posting a build thread when the extension is done and have loads of ideas and ambitions which I hope will not exceed my diy skills
I have spent the last 2 days in the garage cutting MDF in prep as well as built all the columns and soffits.
Old 15-02-2009, 11:29 PM   #17
Quantas's Avatar
16,240, Level: 30
Points: 16,240, Level: 30 Points: 16,240, Level: 30 Points: 16,240, Level: 30
Thanks: Gave 17, Got 8
Well as you know I got a Carada, a tiny bit smaller than yours at 96" across and mine still seems huge.....ooh er missus....So yours will be enormous how big is the extension gonna be
Old 16-02-2009, 10:35 AM   #18
10,249, Level: 24
Activity: 1.9%
The room full size will be 21 foot x 12 foot. There will be a foot either side of my screen. It will be above my 3 front speakers which are M&K S150 on the dedicated ST1 stands. The screen will be on a stud frame which will stand around 1 foot off the front wall. I am doing that as the front wall will have 12 inch corner bass traps and 4" deep acoustic treatment.
Powered by
 Latest popular product prices
Celexon screen Manual Profession...
1 price
 £74.98 Click to show/hide the offers
Celexon Table-top screen 102 x 76cm
1 price
 £108.98 Click to show/hide the offers
Kensington NOBO - Projection scr...
1 price
 £106.79 Click to show/hide the offers
Dell Nobo 2000 X 1513mm Projecti...
1 price
 £139.20 Click to show/hide the offers
1 price
 £154.98 Click to show/hide the offers
1 price
 £146.57 Click to show/hide the offers
WS Spalluto WS-S Screen Fabric -...
1 price
 £169.98 Click to show/hide the offers
Celexon screen Electric Economy ...
1 price
 £204.98 Click to show/hide the offers
 Updated February 13th at 9:30am. Prices include delivery.
