| Re: Help please - electric screen wiring?
Ok guys, just thought I'd give you a final update. Managed to suss out that the white wire was half of the problem. I connected up the white wire to the spare terminal connector and was only getting one way movement, as per my original post. Anyway decided to take the cylindrical tube apart and found inside of that a set of gears which judges the extremes of the screen when raising it up and down. This controlled two micro switches, one for the up limit and one for the down limit. One of the switches had reached it's limit and only allowed the screen to lower and not retract. So I played around with the adjusters and now I'm getting full movement in both directions. I'm now gonna play some more and get the adjustments spot on so when I press down on the remote the screen will automatically drop to the desired level and stop and vica versa when retracting. At the moment though the micro switches are set so they don't kick in and I have to stop the lowering and raising manually. At the moment the screen is hung in place and I'm happy with the temp solution
