Hi Reevesy
If you can find a pair of brackets that are specified to take at least half the weight of the screen, that should do. Just make sure you can (ideally) mount them into the timber framing behind the wall, or use very heavy duty fixings (two for each bracket) if they need to go directly into the stone or plasterboard. If it has to be the latter, I'd be inclined to get a bracket with a long arm to attach to the wall and put three well spaced fixings in each. Whatever you do, you may have a job tidying the finished work to avoid domestic wrath from SWMBO!
George
