| Recommend a 120" Fixed Frame Screen please?
Evening all - looking for some help if you can give it
Took the plunge and bought an Optoma HD20. The room its going in is about 16" x 10" and I want to project the length of it. A north facing window will be behind the projector
The room will be dark ambient light, or close to black as possible. As this will be a dedicated cinema room, I wanted to put up a fixed frame screen, and reckon with the throw distance and the wall width I can go for 120"
I've read a lot about gain, grey, white and matt etc, but am none the wiser....can anyone give me some advice please? this will be for blu ray, sky hd and PS 3
