Projection on glass
Old 09-11-2009, 1:28 PM   #1
1,373, Level: 8
Points: 1,373, Level: 8 Points: 1,373, Level: 8 Points: 1,373, Level: 8
Thanks: Gave 2, Got 0
Projection on glass
Hi everybody. Im looking for flashy and alternate ways to project animation for a presentation. My goal is to achieve some sort of scifi- holographic look with transparent screen and dark lighting. I was wondering if there's some tips & tricks for projecting on glass , transparent plastic or something like that.
My first test on doubleglassed window and animated face YouTube - Projection on glass
Tell me what youre thinkin. Ideas, suggestions etc are more than welcome. Thank you.
Old 10-11-2009, 7:54 AM   #2
2,336, Level: 11
Points: 2,336, Level: 11 Points: 2,336, Level: 11 Points: 2,336, Level: 11
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 2, Got 20
Re: Projection on glass
Hi Raakuna
One of the companies I work for manufacture a film that is applied to glass, take a look at the attached.
Hope this helps?
Rear Projection Displays: 3M UK & Ireland
Raakuna (10-11-2009)
Old 10-11-2009, 10:01 AM   #3
1,373, Level: 8
Wow , this is exactly the look i was lookin for. Too bad i have deadline coming up and i need to fix something like this quickly. But this really helps alot. Thank you
Old 10-11-2009, 11:10 AM   #4
stubie_do's Avatar
12,310, Level: 26
Points: 12,310, Level: 26 Points: 12,310, Level: 26 Points: 12,310, Level: 26
Thanks: Gave 1, Got 34
If you want a quick fix, then thin tracing paper from an art shop.
Spray the window (fine mist) with water and a few drops of washing up liquid,then apply the tracing paper. Slide into postion, then dry with a hairdryer. This will help capture the light rather than losing it through the glass. This is a quick fix though.
Old 10-11-2009, 1:49 PM   #5
1,373, Level: 8
Tried out the tracing paper but it turned out to way too dense to seetrough even with the liquid, but after that I tried applying only a very thin layer of washing up liquid. The very small amount of messy goo on the surface really captured the light beatifully. I might do this smearing trick with a normal window to capture the audience. I mean if it doesnt work i can always wash it off. :D
Really cool trick, i had fun trying it out. Thanks
Suggestions and tips are still welcome.
Old 10-11-2009, 7:45 PM   #6
stubie_do's Avatar
12,310, Level: 26
Did you get it from an art shop? They do different thicknesses You should use water and washing up liquid, just like applying tints to your car
Old 11-11-2009, 2:58 PM   #7
1,373, Level: 8
Ya im guessing the paper i used was way too dense. Gotta experiment more on subject.
Old 12-11-2009, 1:18 AM   #8
AV Nik's Avatar
4,975, Level: 16
Points: 4,975, Level: 16 Points: 4,975, Level: 16 Points: 4,975, Level: 16
Thanks: Gave 45, Got 106
There are a few manufacturers that supply stick on film for glass but it's expensive.
What size area do you need to cover?
One of the cheapest ways to project onto glass is to actually project onto a white cutt-out surface which is set at an angle so the glass reflects the image like a mirror. Without projecting onto the glass, the effect is generally bright and effective.
The theory is used on stages to create illusions etc.
Old 13-11-2009, 2:54 PM   #9
2,187, Level: 10
Points: 2,187, Level: 10 Points: 2,187, Level: 10 Points: 2,187, Level: 10
Activity: 0.7%
Thanks: Gave 13, Got 59
Talk to HoloDisplays. I believe they are the leaders in this area of expertise. If you don't want to pay for a screen, then find a very translucent paint to spray on the back of the glass or buy smoked glass.
Old 15-11-2009, 12:06 AM   #10
johnsattuk's Avatar
6,306, Level: 18
Points: 6,306, Level: 18 Points: 6,306, Level: 18 Points: 6,306, Level: 18
Thanks: Gave 3, Got 5
Coincidentally I have recently contacted ' holodisplays '
84" diag. 16 x x9 holodark ~ 1500 USD deliverd
Old 15-11-2009, 2:47 PM   #11
2,187, Level: 10
Activity: 0.7%
One of the things we told them a couple years back is that they need to make it more affordable. Believe it or not, the price you were quoted is much cheaper than what I was looking at with them a couple years ago.
It's still not where it needs to be though.
Powered by
 Latest popular product prices
Celexon screen Manual Profession...
1 price
 £74.98 Click to show/hide the offers
Celexon Table-top screen 102 x 76cm
1 price
 £108.98 Click to show/hide the offers
Kensington NOBO - Projection scr...
1 price
 £106.79 Click to show/hide the offers
Dell Nobo 2000 X 1513mm Projecti...
1 price
 £139.20 Click to show/hide the offers
1 price
 £146.57 Click to show/hide the offers
Celexon screen Mobile Profession...
1 price
 £164.98 Click to show/hide the offers
Celexon screen Electric Economy ...
1 price
 £204.98 Click to show/hide the offers
Kensington NOBO Portable Screen ...
1 price
 £203.68 Click to show/hide the offers
 Updated February 12th at 2:30pm. Prices include delivery.
