Manual screen - your comments
Old 07-11-2009, 7:58 PM   #1
Eminent Member
152,433, Level: 93
Points: 152,433, Level: 93 Points: 152,433, Level: 93 Points: 152,433, Level: 93
Activity: 80.7%
Activity: 80.7% Activity: 80.7% Activity: 80.7%
Thanks: Gave 1,084, Got 3,334
Re: Roll up manual / electric screen
I concerned about wave, curl on edges over time, as anyone got one and not given them any problems over a long period off time?
It would be going in front off window, so temperature could have an effect in summer and winter seasons.
Deciding between a Beamax manual vs a expensive 'tab-tensioned' electric (dont sell manual for some reason) alternative.
I could save some money going for the first option. Any advice would be great
thanks
rai
Old 10-11-2009, 10:04 AM   #2
Eminent Member
152,433, Level: 93
Activity: 80.7%
Re: Manual screen - your comments
So no one has a 'non tab-tension' manual/electric screen, maybe i should try another forum
Old 14-11-2009, 4:10 PM   #3
Illustrious Member
Pecker's Avatar
43,939, Level: 51
Points: 43,939, Level: 51 Points: 43,939, Level: 51 Points: 43,939, Level: 51
Activity: 16.9%
Activity: 16.9% Activity: 16.9% Activity: 16.9%
Thanks: Gave 2,682, Got 1,888
I have a Beamax R-Series Slow Retraction 169 (244cm x 142cm) manual screen.
I've had it about 12-18 months, I use it around once a week, and so far have had no problems - it still looks dead flat.
Whether that'll change over time, or with heavier use, I couldn't say.
Steve W
raigraphixs (14-11-2009)
Old 14-11-2009, 5:13 PM   #4
10,453, Level: 24
Points: 10,453, Level: 24 Points: 10,453, Level: 24 Points: 10,453, Level: 24
Activity: 14.8%
Activity: 14.8% Activity: 14.8% Activity: 14.8%
Thanks: Gave 89, Got 262
I have a sapphire parklane manual slow retraction screen, about 12 months old, it does show a little curling at the edges but not anything you really notice when watching films and it doesn't appear to be getting any worse.
Old 15-11-2009, 12:31 PM   #5
2,792, Level: 12
Points: 2,792, Level: 12 Points: 2,792, Level: 12 Points: 2,792, Level: 12
Thanks: Gave 22, Got 19
I also have the Beamax R Series manual (10251, same model as Pecker) which has been used on a daily basis for the past six weeks. It's well made, works well, the screen is pretty much flat (slight curl at edges, but not visible in use) and the picture looks good. It also has a very wide angle of viewing, if that's important. For £234 (AV Toad) I think it's a steal. I bought it as a stopgap until I can afford an AT screen with masking, but it does the job to such an extent that I don't feel the same urgency to upgrade now!
George
raigraphixs (16-11-2009)
Old 16-11-2009, 6:58 PM   #6
scrufftyguy's Avatar
9,090, Level: 22
Points: 9,090, Level: 22 Points: 9,090, Level: 22 Points: 9,090, Level: 22
Thanks: Gave 51, Got 46
I've got a beamax too, had it about 2 months, has slight curling but not a problem!
Old 16-11-2009, 10:52 PM   #7
Eminent Member
152,433, Level: 93
Activity: 80.7%
George
Those are a good price for a first screen, and as you say upgrade in the future to meet your requirements if any.
There is no mention off gain on the site for the Beamax screens, so i assume they are matte white 1.0 only?
Old 17-11-2009, 12:09 AM   #8
2,792, Level: 12
Hi, that's right, matte white 1.0. I'm told that Otto who runs Beamax is very helpful, so it's probably worth enquiring to ask if he can do any other fabrics if you need something different (although that will doubtless push up the price).
George
Old 17-11-2009, 12:47 PM   #9
9,090, Level: 22
If you go for a beamax, I can highly recommend AVpeople 16:9 Manual Pull Down Projector Screens they are very helpful if you've got any queries, and were also by far the cheapest when I bought mine.
Old 17-11-2009, 1:34 PM   #10
Ianfromnotts's Avatar
6,340, Level: 18
Points: 6,340, Level: 18 Points: 6,340, Level: 18 Points: 6,340, Level: 18
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 12, Got 169
I have one of these about 8 foot wide and its worked just fine for several years now.
DRH Screens Projection Screen Supplier
Old 01-12-2009, 3:52 PM   #11
4,151, Level: 15
Points: 4,151, Level: 15 Points: 4,151, Level: 15 Points: 4,151, Level: 15
Thanks: Gave 72, Got 35
is it best to install a 92" manual screen on some hard fixings behind the plasterboard (noggins as the builder referred to them !), or can you use some decent plaster board fixings ?
Powered by
 Latest popular product prices
Celexon screen Manual Profession...
1 price
 £74.98 Click to show/hide the offers
Celexon Table-top screen 102 x 76cm
1 price
 £108.98 Click to show/hide the offers
Kensington NOBO - Projection scr...
1 price
 £106.79 Click to show/hide the offers
Dell Nobo 2000 X 1513mm Projecti...
1 price
 £139.20 Click to show/hide the offers
1 price
 £146.57 Click to show/hide the offers
Celexon screen Mobile Profession...
1 price
 £164.98 Click to show/hide the offers
Celexon screen Electric Economy ...
1 price
 £204.98 Click to show/hide the offers
Kensington NOBO Portable Screen ...
1 price
 £203.68 Click to show/hide the offers
 Updated February 12th at 11:30pm. Prices include delivery.
