Cheers for the reply. I'll give that thread a read. The only problems I have with painting it is a) it's permanent, b) it's relatively expensive (roller, paint etc.) and c) it's time-consuming.
However, like you say, a cotton sheet over BOC will still absorb some light, even if the BOC does 100% any light from passing through. I was just assuming that the absorbtion of some light was good when you have a bright PJ.
I agree I might aswell try it as cotton is very cheap, and I'll report back if by some miracle it gives me an image I am happy with
Thanks for your help and i'll read that other thread at some point,
H
