| Re: Bright projector and glass beaded screen ?
As Harpmaker mentions, many Glass Beaded screens are Retro-Reflective (best for tabletop projection), some offer a grainy image, generally used for office type environment with a narrow viewing area.
With your pj, for best image I would recommend sticking with a matte white surface or you could try a High Contrast grey screen which many people with same projector use in average size brightly coloured living rooms.
Sapphire make a matte white, fixed frame screen with a black velveted frame around the size your looking for. Probably the best 'price concious' or cost effective screen you can buy.
Screen International offer the 'Fat Elastic' fixed frame screens and offer the HC version around 15% mor than the matte white version.
Beamax, Draper and Da-Lite all offer their own versions but once on the wall, it's hard to see the difference between those and the Sapphire screens.
Hope this helps.
