AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Projection Screens
LinkBack Thread Tools Display Modes
Old 01-08-2004, 5:07 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Opinions on NexNix 6ft Screen 16:9 Portable Screen
I am moving into shared house while away at uni and need a portable screen. I have seen this at nexnix. Has anyone used one and if so is it any good?
jtorry is offline
Old 04-08-2004, 9:02 AM   #2 (permalink)
lscolman's Avatar
Thanks: Gave 89, Got 48
Hi Tom,
I'm using this screen with the Z1 I bought from you...
http://www.unbeatable.co.uk/CatalogueItem_14438.html
I find it works great. It is quick to assemble, and very well made.
May be worth considering...
Cheers, Lee
If there's anyone with a higher iTrader rating than me, I ain't met them...
lscolman is offline
Old 30-08-2004, 7:21 PM   #3 (permalink)
reviving an old thread here but does the sony have a black border at the sides? Is it 70 inch diaganal? At the moment I'm looking at getting the sony or a DRH lite. The DRH doesn't have a black border and is 4:3. Does anyone have any opinions on either or recomend some other portable screens.
jtorry is offline
Old 30-08-2004, 7:27 PM   #4 (permalink)
lscolman's Avatar
Hi Tom,
Link for you...
The screen is 70" diagonal. It doesn't have a black border.
Cheers, Lee
lscolman is offline
Old 30-08-2004, 7:29 PM   #5 (permalink)
i have read on another thread that it is quite flimsy and has poor build quality. After several months use what's your opinion on it? Thanks
jtorry is offline
Old 30-08-2004, 7:35 PM   #6 (permalink)
lscolman's Avatar
Hi Tom,
It is a little flimsy, in that the screen is not as tight as it could be. I haven't noticed any adverse effects on the image quality.
I've used it about 8 or 9 times, and it's built really well in my opinion.
It is the only screen I've ever used, so bear that in mind.
I would still recommend it. If you don't like it, you could always put in on ebay or the forums. The same model sold for £132 a few months back (£22 more than the price from unbeatable) !!!
Cheers, Lee
lscolman is offline
Old 03-09-2004, 7:41 PM   #7 (permalink)
lscolman's Avatar
Hi Tom,
I have just put the screen up, and found what can only described as a fold in the material, and what look like small squares around it. It's not like you can ignore it either. It's just typical!
Not sure where I stand in regards, getting a replacement. I guess I could put a post on the forums about it...
Have you made a decision on the screen yet?
Cheers, Lee
lscolman is offline
Old 03-09-2004, 9:06 PM   #8 (permalink)
yeah I ordered a DRH screen a few days ago.
jtorry is offline
Old 03-09-2004, 9:10 PM   #9 (permalink)
Hi Jtorry
The lite screen from drh comes in both formats but is only 4:3 on the website Cheers
Andrew
Mr Screen is offline
169, 6ft, nexnix, opinions, portable, screen
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
