Vaio vgf-ap1l volume cap blues
Old 25-06-2005, 5:51 PM   #1
john123
Posts: n/a
anyone know of any news about a way around the euro volume cap on my pocket vaio
Does it have a factory menu like older versions ....supose if there was a way to unlock the volume it would be allover the net by now .....wonder if it is possible?
also i hear there is a crack to use mp3 format instead of the sony format this true?
Cheers john
Old 25-06-2005, 6:15 PM   #2
watchinthewheel
Posts: n/a
there is a firmware update from sony that will let you play mp3, im, not sure about volume removal though i would guess the same applies to the vaio as the hd series, have a quick search on this forum for volume unlock code.
Old 25-06-2005, 6:54 PM   #3
johann1979's Avatar
9,979, Level: 23
Points: 9,979, Level: 23 Points: 9,979, Level: 23 Points: 9,979, Level: 23
I'm not aware of a volume unlock code for the vaio - the problem is it has a touch pad and no buttons, so the forward, forward, back, back, forward, back, forward, back, up and down code wouldn't be able to work.
Go and get the firmware update from www.vaio-link.com - it is definitely worth the hassle and will allow you to play mp3s as well as atrac - it will also make the player completely gapless between tracks.
Old 25-06-2005, 8:01 PM   #4
Grey Area
Posts: n/a
Hmm, there is a European firmware upgrade and a North American one - has anyone been brave enough to upgrade a European player with the American firmware? Could this have an effect on the volume capping?
Björn
Old 25-06-2005, 8:35 PM   #5
john123
Posts: n/a
cant see why american firmware would make any difference its still the same machine afterall
Old 25-06-2005, 8:47 PM   #6
Grey Area
Posts: n/a
Well, with the Minidisc players and the NW-HD-series the volume cap is not a hardware limitation. European and non-European machines are the same physically, they only differ in their settings, which can be changed by entering the service mode.
If the situation is similar for the Vaio Pocket, then replacing the European firmware with the American version could erase the internal volume cap settings. I have read somewhere it works that way for iRiver players.
Of course, if there are hardware differences between European and non-European Vaios, then this won´t help (and might be impossible).
Björn
Old 25-06-2005, 9:11 PM   #7
john123
Posts: n/a
i will try the american firmware i cant see any possible risk of killing my vaio pocket
Old 25-06-2005, 9:16 PM   #8
john123
Posts: n/a
maybe not it warns to only use with american players
im not brave enough
anyone tried the usa firmware?
Old 05-07-2005, 6:36 PM   #9
ascaria
Posts: n/a
I was brave enough
Check the returns policy of the vendor you used. The hardware is preety much the same. I would say if you were brave enough to upgrade the firmware to version 3.0 to support mp3 you are brave enough to try the other areas firmwares. I did so with my VGF-AP1L between Japanese and American firmwares and it works just fine. If we assume that the hardware is the same, then the volume cap for european devices should be removed by installing the american version. Hope it helps.
Old 12-07-2005, 10:25 PM   #10
fedevi
Posts: n/a
anyone tried the usa firmware?[/QUOTE]
Up...
Old 14-07-2005, 9:30 PM   #11
fedevi
Posts: n/a
I try the USA driver: nothing is changed... the volume is low...
Old 09-10-2005, 7:00 AM   #12
mercedes500e
Posts: n/a
Cool
i Tried it, didnt make a difference i havn't tried the MP3's on it though do they need to go into a folder or does it go straight into the root directory?
Dan
Old 09-10-2005, 9:27 AM   #13
shadowritten
Posts: n/a
Björn
Works with Creative players, too!
Powered by
 Latest popular product prices
Samsung YP-F3 4GB
2 prices from
 £17.99 Click to show/hide the offers
Samsung YP-F3 2GB
2 prices from
 £18.49 Click to show/hide the offers
Archos 18c Vision 4GB Black
5 prices from
 £19.49 Click to show/hide the offers
Goodmans GMP38G9 8GB
1 price
 £35.81 Click to show/hide the offers
Samsung YP-Z3 4GB
2 prices from
 £31.00 Click to show/hide the offers
SanDisk Sansa Clip+ 8GB Black
3 prices from
 £34.50 Click to show/hide the offers
Creative Zen Style 100 4GB Black
1 price
 £34.99 Click to show/hide the offers
Apple iPod Shuffle (4th Generati...
12 prices from
 £37.80 Click to show/hide the offers
 Updated February 13th at 6:30pm. Prices include delivery.
