Sonicstage 3.1 won't load arghhh!!
Hi everyone,
So I received my brand new HD-NW5 30gb a few days ago. But have not been able to use it yet! The reason, Sonicstage 3.1 won't load. It gets to the text in the loading box saying 'Loading Libary' and then a popup box comes up and says:
"Updating SonicStage database.
SonicStage will be restarted after the updating has completed"
You then click 'ok' on this box and thats it, SonicStage just goes never to be seen again. You click on sonicStage again and it just repeats this exact same thing.
So quite annoyed about this I checked the SonicStage 3.1 OS environment requirements and found the following:
# Operating systems other than those indicated above
# Personally constructed PCs or operating systems
# An environment that is an upgrade of the original manufacturer-installed operating system
# Multi-boot environment
# Multi-monitor environment
# Macintosh® operating system environment
So does this mean that everyone who has Windows servicepack 2 can't use there brand new £239 NW-HD5. Because there is no alternative instead of SonicStage for transfering files to your device. I sent a very annoyed e-mail to sony support on this but have received no reply.
I don't know what to do. Can anyone offer an advise on this? I've already tried uninstalling and reinstalling the program but it still does the exact same thing every time.
Thanks,
Pete
