NW-HD3 NW-HD5 NW-HD5H EU model volume? SOLVED !!!!!
Old 30-01-2005, 3:46 PM   #1
15,118, Level: 29
Points: 15,118, Level: 29 Points: 15,118, Level: 29 Points: 15,118, Level: 29
Thanks: Gave 0, Got 11
Bingo
I've decided to open a new thread just because the low volume level of the EU models is the only issue that may prevent someone from buying this terrific piece of hardware. I've struggled with it, but finally (with a help of Sony related people) found a solution.
There are many things in NW-HD3 you can adjust via a service menu. To enter it
follow the instructions from testmode.jpg.
When you are in, follow soundpressure.jpg to set "Sound Pressure Regulation" to OFF.
You are done!
Disclaimer. I take no responsibility for any consequences caused by this. Using service menu is inherently dangerous, difficulties during the process could cause the device to stop functioning and irreparably damage the product. If you do damage the product in this way, your supplier will charge for repair.
Here are the specific instructions for the HD5 (as posted later in this thread)
Start the player. Start playing a song. Turn the HOLD function on by sliding the swich at the top. Then, Hold the SEARCH/MENU button and enter the button sequence:
Right, Right, Left, Left, Right, Left, Right, Left, Up, Down.
Let go of the buttons, and put the HOLD switch back to its original position.
The backlight will cut out and you'll be in the service menu with "POWER" displayed.
Press DOWN a few times to select OTHERS and press Right to get into the menu.
Keep pressing down until you get to SP SET (Sound Pressure Setting).
Press Play/Pause to get into change the option. Then press SEARCH/MENU to
toggle the option on or Off (obviously, Off is for louder sounds).
Then either hold STOP or remove the battery to get the player out of the
service mode. For some reason, you'll have to go back into the player's options to manually turn the backlight on again after doing this.
(Note that the attachments below apply to the original HD3 instructions.)
[mod comment - instructions for HD5 copied here by JohnG]
NW-HD3  NW-HD5  NW-HD5H EU model volume? SOLVED !!!!!-testmode2.jpg   NW-HD3  NW-HD5  NW-HD5H EU model volume? SOLVED !!!!!-soundpressure.jpg
Last edited by JohnG; 22-06-2005 at 7:18 AM. Reason: Included instructions for HD5. Also re-posted jpeg files as problems when downloading
Ade-UK (29-04-2006), cloud_dancing (27-01-2006), David Mackenzie (30-03-2007), emilicious (24-04-2006), fletpablo (24-07-2006), Gxark (20-07-2006), jimani (24-02-2006), satin_cookie (06-06-2006), Seanferg (23-03-2006), sheilas1 (27-05-2006), vityok (24-02-2008)
Old 30-01-2005, 6:41 PM   #2
3,572, Level: 14
Points: 3,572, Level: 14 Points: 3,572, Level: 14 Points: 3,572, Level: 14
Thanks: Gave 38, Got 17
Followed instructions for my HD3.
Initially got into a menu where you only get choice of "CHG", "A WR", "A RD" and "V CHK" ,
Tried again and got into the menu as described. Followed instructions and.....
it goes much louder!
Great help, many thanks for the info.
Old 30-01-2005, 9:04 PM   #3
5,300, Level: 17
Points: 5,300, Level: 17 Points: 5,300, Level: 17 Points: 5,300, Level: 17
Thanks: Gave 30, Got 14
as previous reply, followed instructions into set up mode, had to find my way around a little blindly, but after the switch, it definately works!
Old 30-01-2005, 9:51 PM   #4
Lex69
Posts: n/a
worked for me as well - but beware that when i did it, it set backlight to "off" and for a few seconds i thought i had screwed it up, but i just turned it back to auto in the menu
Old 30-01-2005, 9:52 PM   #5
4,990, Level: 16
Points: 4,990, Level: 16 Points: 4,990, Level: 16 Points: 4,990, Level: 16
I'd be really interested to know if there is a similar solution for the HD1. I'm not sure if the controls are identical.
Old 30-01-2005, 11:36 PM   #6
15,118, Level: 29
Since the solution is menu based, you can't really go wrong... It either works or not. If you manage to enter the service menu and find an option "Sound Pressure Regulation", it should just work.
Old 31-01-2005, 10:07 AM   #7
philou
Posts: n/a
It's working on my HD1 too.
Old 31-01-2005, 11:05 AM   #8
nimrodity
Posts: n/a
that is great,when i get my hd1 back from the mp3-upgrade i have to try this,cool
Old 31-01-2005, 11:40 AM   #9
4,990, Level: 16
The reason I asked about the HD1 is because the instructions for adjusting the sound pressure show a single horizontal arrow key, whereas mine are double arrow keys. Presumably that's what you use - there aren't any others!
The instructions also talk about applying power to the unit. I don't suppose this means it has to be plugged into the charger.
I'm thinking about getting the Mp3 upgrade, so it would probably be best to wait until after that before attempting the mod.
Old 31-01-2005, 1:55 PM   #10
LFC LFC is offline
3,717, Level: 14
Points: 3,717, Level: 14 Points: 3,717, Level: 14 Points: 3,717, Level: 14
Thanks: Gave 0, Got 3
How does this affect the battery life of the player?
SO far I have found at max levels vilume is fine only issue is ripping from CD's that have different volume levels
Old 31-01-2005, 3:57 PM   #11
andrew1979
Posts: n/a
IT WORKED!!!
I too loved the style of the HD3 but wished I could up the volume a bit. Thanks heaps for your tip! Now the HD3 is the best!
My backlight went off too. Once player was back on, I just went into the normal menu and turned it back on.
I noticed a menu in the admin section called 'clock'... any idea what this is for? I presume there must be a clock feature built in. Anyone had a play?
Why don't they enable all these features from the onset. Anyone found any more reference material out there on these types of functions?
Old 31-01-2005, 4:40 PM   #12
3,572, Level: 14
Yeah, my backlight did the same thing too.
I noticed heaps of interesting looking features that one might tinker with.
I guess Sony don't let us access them coz idiots like me would ..... well.... tinker with them and mess everything up.
Old 31-01-2005, 5:42 PM   #13
4,990, Level: 16
I finally screwed up the courage and gave it a go with my HD1, and guess what - it works, and is appreciably louder. Don't know what the Sony people will say when I send it back for its mp3 upgrade - I wonder if I get the same one back!
Old 31-01-2005, 5:50 PM   #14
salford_sniper
Posts: n/a
Thumbs up
[FONT=Comic Sans MS] Fookin Magic!!!
This has worked an absolute treat. I thought i was in for a life of substandard volume but thanks to this fix i can finally get my HD3 up to a suitable volume. A must for any HD3 owner. No problams when fixing but I would recomend not to get too button happy while doing this though. [/FONT]
Old 31-01-2005, 6:10 PM   #15
truepalace
Posts: n/a
Well LOUD happy mate cheers!!!
HD1 user
Bit tricky to do but !!!!!
cheers
Old 31-01-2005, 6:27 PM   #16
ben_wade
Posts: n/a
Thanks, it really does work!
Was reading this thread when the backlight went off on my HD1 and what you have to do to just clear things up is go into the menu thay you're meant to be able to access, not the secret menu and go onto backlight and turn it on
Old 31-01-2005, 7:06 PM   #17
Ekko Star's Avatar
17,890, Level: 32
Points: 17,890, Level: 32 Points: 17,890, Level: 32 Points: 17,890, Level: 32
Thanks: Gave 23, Got 202
Thanks works on a HD1 ! My ears hurt it's so seriously loud now
I bet the native MP3 settings are in here somewhere as well.
Old 31-01-2005, 8:02 PM   #18
dogslikeyou
Posts: n/a
must be really thick but it don't work for me! holding down menu and have the hold on following the instructions too The letter but no luck :-(
Old 31-01-2005, 8:07 PM   #19
Ekko Star's Avatar
17,890, Level: 32
I bet your not switching the HOLD off after the key depressions
Old 31-01-2005, 8:17 PM   #20
dogslikeyou
Posts: n/a
and keep menu held down?
Old 31-01-2005, 8:24 PM   #21
dogslikeyou
Posts: n/a
sorry mode button? have tryed holdin down the mode button doing the depressions then taking off hold whilst hold mode and relising it!!!
Old 31-01-2005, 9:11 PM   #22
dogslikeyou
Posts: n/a
cracked it and just gone deaf!!!!!!!! Fookin ace well done that man! and thanks to Ekko Star i was just being a bit thick!!! :-)
Old 31-01-2005, 9:23 PM   #23
Ekko Star's Avatar
17,890, Level: 32
Nice one man ! Yes it's too bloomin loud now. If you''ve got fairly decent headphones it's plenty loud as it is I reckon. Either way they're ace machines
Old 31-01-2005, 10:04 PM   #24
4,187, Level: 15
Points: 4,187, Level: 15 Points: 4,187, Level: 15 Points: 4,187, Level: 15
Thanks: Gave 25, Got 16
Sorry to be thick but it doesn't work for me at all, can anyone describe how it works?
Old 31-01-2005, 10:16 PM   #25
Ekko Star's Avatar
17,890, Level: 32
Slide the hold switch on, hold down the mode button and depress the instructed sequence of buttons on the navigation controller. Release the mode button and then slide the hold switch off.
The screen will be dark and you will be in the service menu.
Navigate to Others, scroll through to SP and toggle ON as per instructions.
Exit by pressing the menu button and holding it down, the player will restart itself.
Old 31-01-2005, 10:16 PM   #26
dogslikeyou
Posts: n/a
yeap i can!
turn on your player and stop the music playing! then switch on the hold button press and hold down the mode button. follow the instructions on the previous page and take hold off after the sequance your screen should go dark and you should be on the menu screen! hope it helps! it does work!!!
Old 31-01-2005, 10:18 PM   #27
dogslikeyou
Posts: n/a
has anybody played with any of the other features on the service menu yet!
Old 31-01-2005, 10:31 PM   #28
nimrodity
Posts: n/a
yeah th eother features in the service menu would be interesting,could it be possible to turn up the bass level a little bit or something like that
Old 31-01-2005, 10:41 PM   #29
KMH
Posts: n/a
Works on my NW-HD1 as well, thanks.
Any chance of the rest of the service manual being made available?
Old 01-02-2005, 1:08 AM   #30
chrzapitis
Posts: n/a
has anyone tried the trick with an upgraded HD1?
did it still work?
i suppose it should...
Powered by
 Latest popular product prices
Samsung YP-F3 2GB
2 prices from
 £17.29 Click to show/hide the offers
Samsung YP-F3 4GB
2 prices from
 £17.99 Click to show/hide the offers
Archos 18c Vision 4GB Black
5 prices from
 £19.49 Click to show/hide the offers
Goodmans GMP38G9 8GB
1 price
 £35.81 Click to show/hide the offers
SanDisk Sansa Clip+ 4GB Black
3 prices from
 £30.00 Click to show/hide the offers
Samsung YP-Z3 4GB
2 prices from
 £31.00 Click to show/hide the offers
SanDisk Sansa Clip+ 8GB Black
3 prices from
 £34.50 Click to show/hide the offers
Creative Zen Style 100 4GB Black
1 price
 £34.99 Click to show/hide the offers
 Updated February 11th at 6:30pm. Prices include delivery.
