I need to convert an old cassette tape that means a lot to me for listening via CD / PC.
I'm looking for something very safe, reliable and easy to use. My budget is up to £300 but I could go higher.
The tape itself is quite old and probably low quality. It's a demo tape done as home recording.
I found the "Ion Tape 2 PC" system online, which seems reasonably priced but I noticed that it gets low marks on quality (
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/audio-systems/ion-tape2pc-usb-cassette-deck-455009/review )
I don't really know how much this matters given that the whole tape is very likely to be quite ramshackle.
Does anyone have any recommendations? I don't really want to set up any complex systems myself. I also don't have a tape player or any other sound system, so I will need to buy hardware anyway and an "all-in-one" system does appeal due to its simplicity. I'm also terrified of the tape being eaten up or damaged in any way, as it's an only copy.
I will want to listen to the tape on CD (played via DVD/blue ray player); and then also converted to iTunes format (iPod).
Hope this all makes sense, help would be really appreciated.
Edith
