Originally Posted by BIGDENNIS10UK From my independant research (I looked on Amazon  ), i think the Sansa Clip looks like a good option.
8gig for 50 quid and looks snazzy enough.
Anyone got first hand experience? |
I got the Sansa Clip+ last week as I was fed up of my old iPod nano and iTunes.
Small, light and easy to use. Radio reception is average (has presets), and the Plus version has a card slot which can be used to increase the capacity if needed. The OLED screen is a bit small, but is clear and bright so can be read easily in daylight.
I've been using MediaMonkey to sync mine, but it can also be done drag and drop instead.
It cost £49.99 for the 8GB version at my local Dixons (as was).
<edit>
Forgot to say that the Plus version has the addition of a card slot, but unlike the original doesn't have a removable clip (it's fixed in place), and the buttons don't light up when pressed... neither of which have been of any concern to me!
